Disc Brakes — Hydraulic vs. Mechanical?
Our Community › Forums › Bikes & Equipment › Disc Brakes — Hydraulic vs. Mechanical?
- This topic has 98 replies, 26 voices, and was last updated 7 years ago by
hozn.
May 25, 2017 at 7:13 pm #919432
Dan K
ParticipantGreetings All –
Stepping up from my 5 year-old Jamis Coda Sport this Fall. Staying with the Coda (love the steel), upgrading to either the Comp (which has mechanical discs), or the Elite (which has hydraulic discs).
In terms of hydraulics vs. mechanicals, looking for opinions regarding both performance and upkeep (frequency and cost).
Thanks in advance!
May 26, 2017 at 3:52 pm #1071402
bentbike33
Participant@huskerdont 160689 wrote:
I had a bit of a brain freeze and confused two of my bikes. The CX bike still has the lousy Promax brakes, so when I upgrade that one, I probably will do either hyros or the Hy/Rd you suggest. (It’s my rain bike that I upgraded to Spyres. They actually work well enough that I won’t re-upgrade them. It’s just that if I don’t keep them adjusted, sometimes I need to augment the rear brake with the front, especially when wet. Not really a problem, but a touch disappointing compared to the BB7s on the MTB.)
I put Spyres on an older bike I converted from road calipers, but the brake levers were Sram MTB levers whose pull length I never officially looked up. I thought the Spyres worked really well. So, when I built up my new bike, I also put on Spyres, but this time I used some old MTB cantilever brake levers I had around, because they were free and light. These levers are definitely short pull as they (barely) predate V-brakes. The Spyres felt mushy on the new bike and needed to be dialed in about weekly (200 miles or so) to avoid bottoming the levers. So I switched the levers to these which can be coverted between long and short pull. In the long-pull setting, the Spyres feel much more solid like on the old bike, so that’s where I left the new levers. I guess this means I have to squeeze the levers harder to get the same level of stopping power as with the short-pull levers, but not so much that I can say I notice it. But then, I don’t tend to ride the brakes on long descents much.
May 26, 2017 at 3:55 pm #1071403EasyRider
Participant@dkel 160706 wrote:
My mechanical discs are not noticeably more efficient for braking than rim brakes I use. Most importantly for me, though, discs are way nicer for commuting because they require far less attention during and after riding in crappy weather: they function more consistently, last longer, and make far less mess in the wet and muck.
Can you recommend pads for the BB7, if that’s what you have? I’ve found that most rim brake pads suck, only Kool-Stops work, and work well they do. Is the same with discs, that all the stock pads mostly suck and everyone buys a replacement that doesn’t?
May 26, 2017 at 4:01 pm #1071404bentbike33
I have some Aztec pads for BB7s I can give you as I don’t have the bike with BB7s any more. Send PM if interested.
May 26, 2017 at 5:05 pm #1071409hozn
ParticipantStock Avid pads are great. As are Jagwire, Koolstop, etc. The main difference is metallic vs organic (the latter wear faster but are quieter and may offer better feel). I haven’t found much of a difference between pads of the same general type. Main benefit to Aztec etc. is cost.
Rotors make a significant difference. E.g. I think TRPs rotors (at least the older models) are terrible. Avid HS/HSX I like a lot.
May 26, 2017 at 6:54 pm #1071416dkel
On one bike I have a set of Spyres with stock TRP rotors and on another bike I have a set of Spyres with Avid HS rotors. I rode those HS rotors with BB7s for thousands of miles, and they were fine, but very noisy; I have only a couple hundred miles with those same old HS rotors paired with Spyres, but so far they are super quiet and work very well. On the bike with the stock TRP rotors, after 1500 miles now I think I have finally lost my patience: there may be an issue with my pads or caliper alignment, but in the last two weeks my front brake has become all but useless. It shudders and is constantly squishy, and won’t stop the bike even on a slight descent; I have to rely on my rear brake on that bike, which still seems to work well for some reason. I’ll investigate pad wear on the front end, but ultimately I may just swap out the TRP rotors for Avid HS anyway, because they work so well on the other bike.
May 26, 2017 at 8:05 pm #1071420hozn
Yeah, shuddering was definitely one of the features of the TRP rotors. They also just didn’t stop as well for me. Check eBay for HS rotors; I found a pair for $12 recently.
May 27, 2017 at 5:31 pm #1071430ShawnoftheDread
Any difference between rotors listed as MTB rotors and road rotors?
May 27, 2017 at 6:51 pm #1071431TwoWheelsDC
FWIW I bought rotors for my MTB, sold the MTB, then just put the rotors on a new CX wheelset.
May 27, 2017 at 8:08 pm #1071433Birru
Road disc is relatively new and at least with Shimano the road and MTB rotors are the same (Dura Ace excepted). The biggest difference will be rotor size. Road rotors are usually some mix of 140-160mm whereas going all the way up to 200mm or so might be necessary for say MTB downhill.
May 28, 2017 at 2:22 am #1071437Judd
Participant@Dan K 160651 wrote:
Greetings All –
Thanks in advance!
Whichever one you go with, don’t pull a Judd and wait 5,200 miles to change your brake pads. Just changed mine tonight.
May 28, 2017 at 2:36 am #1071438Birru
Damn, dude. If your rotors made it out unscathed color me impressed.
May 28, 2017 at 12:40 pm #1071439mstone
Which, for me, is where road disc goes off the rails–the rotors on road bikes aren’t smaller because physics, they’re smaller because the frames aren’t designed to accommodate larger rotors and because roadies want tiny decorative light rotors. But physics suggests that a road bike running down a steep grade at 30+ MPH needs a lot of brake capacity.
May 28, 2017 at 1:43 pm #1071441Birru
I don’t know about that. I think weight wheenieness plays a certain role, and beefier frames that can handle higher braking forces are going to be heavier. Like anything I’m sure there are compromises to meet the design goals. My gravel bike is 160mm/160mm and I’ve got more than enough braking power. I know Niner’s post-mount gravel fork can accommodate up to a 180mm rotor, which should be enough braking power for anyone who isn’t sponsored by Red Bull and making jaw-dropping YouTube videos.
May 28, 2017 at 7:20 pm #1071442hozn
ParticipantYeah, I do think that 160/160 is prudent, but road descents are also a lot less steep than MTB descents — especially the ones where people fit 200+mm rotors. On the road one can brake hard and release to cool the rotors, but good luck doing that sliding down a mountain on dirt.
Anyway, I have 160/160 on my road and CX bikes and it is plenty of stopping power, even with one hand. But I also rented a bike with Shimano ice tech 140/140 rotors in Switzerland and I did not have the same over-abundance of stopping power that I have on my SRAM bikes. It was sufficient, but if it were my bike — and I lived there — I would have put 160s on there.
Incidentally, until this past season I also ran 160/160 on the MTB which was fine for anything I’d ridden, even with mechanical brakes. I figured I’d upgrade the front to 180, since it’s what the cool kids do. That was probably useful for SM100.
May 29, 2017 at 10:50 pm #1071455dkel
I worked on this today, and I clearly need new pads on the front end. I’ll do that before I replace the rotors, and see if it fixes my problem. Those HS rotors are tempting, though…
