Dimming or shielding lights
Our Community › Forums › Commuters › Dimming or shielding lights
- This topic has 18 replies, 12 voices, and was last updated 11 years, 6 months ago by
dkel.
December 6, 2013 at 3:14 pm #987796
Geoff
ParticipantI shield my light sometimes – I used to never do it. If the light isn’t too bright and is directed down I don’t think shielding matters much, but since the practice gets a lot of support here I’ll do it as a matter of trail etiquette.
Something else that gets discussed here is blinking lights. The consensus seems to be that they are OK on roads but should not be used on a trail. My wife recently told me she passed a bike with a blinking light while driving, and found it very annoying / distracting. She asked me to never set my light on “blink”.
December 6, 2013 at 4:28 pm #987825CPTJohnC
Was she sitting behind it for a long time? I imagine that if she was, she was stopped? If not, I’m curious to know more about the situation, as I find it hard to believe there are many circumstances in which motorists could be significantly impacted (as in actually distracted — I don’t really have much concern about their ‘annoyance’ – esp. when most of them find our very existence on ‘their’ roads to be ‘annoying’) given that most of them pass most of us in a matter of seconds. It is NOT like being another cyclist following a blinkie on a trail where the overtaking might take 30 seconds or more.
I’m sure that your wife is cyclist conscious and friendly, so can you dig into this a little? I’m not about to limit use of blinkies on roads without knowing a lot more, as I find it takes a certain amount of ‘annoying’ to be noticed, and even the brightest rear bike light is not much of a presence on steady, in the sea of automobile tail and brake lights. I will note that ‘blink’ is nearly synonymous with ‘hazard’ which is why emergency vehicles, tow trucks, school buses and other similarly situated ‘special cases’ use them. I consider bikes to be in at least as much jeopardy as a 45 foot long, 16 ton plus school bus.
December 6, 2013 at 4:35 pm #987828mstone
you are not sufficiently thinking of the children!
edit to add: unless the kids are on bikes, then they’re screwed like the rest of us
December 6, 2013 at 4:40 pm #987830dbb
If I am stopped at an intersection behind a car, I try to turn my wheel or rotate the strobe light (NiteRiders can be particularly effective/annoying) so it isn’t blasting into the back of the stopped car just ahead of me. Once we start moving, all bets are off.
December 6, 2013 at 4:42 pm #987831rcannon100
The goal is not to blind oncoming cyclists. This can be achieved in a number of ways.
* First, no strobes on the trail. Just dont do it.
* Point your beam down towards the trail
* Shield the light with your hand. or
* Set your light to the lower setting (on the Custis and MVT there is lots of other light from other sources)Too frequently ppl have high beams on handlebars pointed straight forward – where straight forward means into the face of the oncoming cyclists – and all the oncoming cyclists is the great orb of the almighty hallucination. (and if it strobing you cant see nada). Even that great evil transportation tribe -> cars – does a better job than we do. Be default, regular headlights are pointed DOWN at the road, not into the face of oncoming traffic. High beams are not only more powerful, they are… “higher”. And the etiquette (and the law) is to turn off high beams for oncoming traffic. I would like to put car drivers up on a pedestal for magnanimous driving behavior! (oh, a cold shiver just went down my spine…. I have to go do 10 Hail Hains Points to atone for that sin).
December 6, 2013 at 5:00 pm #987833bobco85
I do the same, tilting my helmet light down and either turning my front wheel or tilting my handlebar light down until the light turns green. However, I keep the rest of my bike facing straight ahead so that cars approaching from behind me will see my rear lights and (I assume) not hit me while I’m standing there.
December 6, 2013 at 5:01 pm #987834mstone
ParticipantQuote:I would like to put car drivers up on a pedestal for magnanimous driving behavior!You can observe the rise of HID & blue-tinted lights and recover your disdain for motorist manners. Note that the research, however, does not show any increase in actual accident rates due to those lights, only an increase in bitching…
“agitation over the effect of glare caused by powerful headlamps has gradually increased until we are threatened with drastic legislation.” — From a 1917 paper addressing complaints about the new-fangled and unnecessary electric headlights which were so much brighter than the normal acetylene lamps.
December 6, 2013 at 5:14 pm #987835pfunkallstar
ParticipantWon’t someone think of the epileptic children?!!?? (Reverend Lovejoys Wife voice). Seriously though, the mega strobe rear blinkers are equally unnecessary, but at least they provide an incentive an ELITE POWER PASS.
December 6, 2013 at 5:32 pm #987837Geoff
I may have been misleading – the bike was oncoming and the blinking light was a bright white handlebar light. I think the strobe effect is what did it for her. It didn’t even do much to make the rider standout. At first she thought a nearby car had a flashing headlight. So I now use a steady beam and rely on an array of reflectors to make me stand out.
December 6, 2013 at 5:44 pm #987839Amalitza
I have an amazingly bright light (which I run on low or medium on the trails) that I tried to put on strobe once. It definitely strobed on “high”, not medium or low. It was quite distracting *to me*, sitting on my bike behind it. So I don’t use it. I honestly think that if I did, it *would* be distracting to oncoming drivers.
Not necessarily the case here, but can easily believe it. There are some pretty bright strobe lights out there, not just standard blinkies and such.
December 6, 2013 at 5:46 pm #987840OneEighth
ParticipantI cover whenever I can and thank anyone else who shows me the same courtesy. I could do unto others as they do unto me, but I suspect that the weather is about to take care of things.
December 6, 2013 at 5:59 pm #987846dkel
* Point your beam down towards the trailI know the lighting thread is a favorite(!) on the forum, and I don’t want to prolong it unnecessarily or backtrack to prior threads, but since I’m still relatively new to riding at night, I’ll just go ahead and ask: how far down is “towards the trail”? I find that my cone of light doesn’t help me very much at 6 feet ahead of me, but it’s great at 15 feet ahead. Beyond that, my light isn’t bright enough to make a lot of difference, so I never turn it to a higher angle. Do some riders feel there is benefit to pointing their bar light straight ahead? That doesn’t make sense to me. In general, I am coming to understand that oncoming lights don’t bother me personally, but I get positive response from most other trail users when doing all the etiquette things I’ve learned from this forum, so I do them all, all the time; it’s no trouble for me.
I also show no mercy to ninjas (if I did, I really wouldn’t be able to see them).
December 6, 2013 at 6:45 pm #987853mstone
At 20MPH, 15 feet is half a second. At 15MPH, 15 feet is two thirds of a second. Apply your own speed & response times and then buy the appropriate light.
December 6, 2013 at 6:59 pm #987857dkel
If I get a 12 mph average for my nighttime commute, I feel like I’m going pretty fast for the conditions. Thanks for the math; that puts it in perspective.
December 6, 2013 at 7:18 pm #987859mstone
The other piece is that at 20MPH it’ll take you 15 feet to stop, so you have 0 chance of avoiding something if you can only see 15 feet ahead (plus reaction time). At 12MPH you’re probably ok seeing to 15 feet as long as the pavement is dry and your reaction time is good (and your average isn’t based on speeding up down a hill
