determining valve hole size on a wheel set
Our Community Forums Bikes & Equipment Maintenance determining valve hole size on a wheel set
  • #918869
    Thanks to KWarkentian for lending me a bike.
    Upon further examination of the bike, it reveals a question for the forum. The wheelset is Mach 1 CFX, and the tubes KW had in them were Prestas. I continue to want to want to use my bikeroom motorized air pump for quick inflation, and it is schrader only (the bike room has, or at least had, presta-schrader adapters, but I find using them awkward) I would like to switch out the presta tubes for schrader tubes, but without taking the tubes out its hard for me to see the valve hole on the wheelset to see if there is actually room to do that. I have found wheelset specs online, but nothing about valve hole size. Is there some other way to figure this out easily without taking the tube out?
    If not should I
    1. Go ahead and take the tube out, because that is such a basic easy thing to do
    2. Just man up and use the adapters, because presta good, schrader bad.
    Assuming I find out that the holes are sized for presta and not schrader, I will have to do number 2 anyway. Even if KW gave permission (chance to chime in here!) I don’t think I would want to drill the wheels.
Viewing 11 replies - 1 through 11 (of 11 total)
  • #1061657
    What do you mean it’s hard to see the valve hole? If the hole is Schrader-sized, but the tube has a presta valve, it should be pretty obvious. Do you mean it’s hard to see because of the nut on the valve stem? That nut has essentially no use whatsoever (except when you’re installing an empty tube), so you can just remove it and see if there’s a big gap between the valve stem and the edges of the valve hole. No gap = presta only.
    #1061658
    yes. I haven’t touched the valve stem nut.
    #1061660
    Just take that off and you should be able to tell pretty easily…no tube removal required. Like I said, the nut does nothing once the tube is inflated…it’s only purpose is to hold the valve stem in place when you’re attaching a pump to an empty tube.
    #1061862
    Finally went down to the bike room and checked it out. Those are definitely small prest sized hold on the wheels.
    I’m thinking the reason I have trouble with the adapters is that they are not standard adapters. Does this look like a presta schrader adapter?
    [ATTACH=CONFIG]12962[/ATTACH]
    I think I need to go pick up some simple adapters.
    #1061867
    No, that looks like something you’d use to inflate a kiddie pool with a (shraeder) floor pump.
    Any bike shop should have a presta-shraeder adapter. Which I guess is useful if you want to use free trail-side air.
    #1061869
    Or the pump in my building bike room.
    #1061909
    Really, a schraeder-only pump head?!? Someone should tell them that bicycles use presta valves. I don’t think you could even buy a pump from a bike store that wasn’t dual head (or presta-only). Maybe you could find a schraeder-only pump at Target, though.
    #1061905
    It’s an auto style compressor, not a floor pump. I don’t know where they got it, or how they decided to install it. They only asked me about bike room needs a couple of times at most, and I think my main focus was on it being fob accessible (the old bike room was and is opened by keys kept only at the front desk, so not accessible at hours when the concierge is not in). I didn’t expect the tools and the pump the put in. And I am not about to complain about it.
    #1061899
    If you want to be nice guy, you can spend <$10 to buy this press-on presta valve adapter, which you can zip tie close to the end of the hose. When you want to use it, you can just press on the adapter onto your Presta valve tube, then use the Schraeder valve compressor pump. It's nice and quick because you don't have to screw it onto either, and it's always handy because it'll be zip tied onto the pump. [ATTACH=CONFIG]12969[/ATTACH] It’s available from QBP, so any shop can order it, or you can get it directly here: http://www.aebike.com/SKS-Pump-Adaptor-with-Chain-Schrader-to-Presta_p_21402.html
    #1062224
    Just to wrap this up, I bought a pair of the ordinary cheap adapters, and they work fine.
