Custis Trail Work – 8/22/16
Our Community › Forums › Road and Trail Conditions › Custis Trail Work – 8/22/16
- This topic has 15 replies, 10 voices, and was last updated 8 years, 10 months ago by
Steve O.
August 17, 2016 at 2:15 pm #1057657
Tania
ParticipantOh man! Is that mogul run? I enjoy those. Plus, heading west right after you cross 66 and turn right (at the new MOM’s) and start heading downhill, there’s a frost heave/rooty bump that I hit with speed and use to catch some air (“WHOOOOOP!”).
Sad face.
August 17, 2016 at 3:24 pm #1057666chris_s
Participant@Tim Kelley 144533 wrote:
This work is in connection with an investigation of the pavement settling / buckling that is occurring on the south side of I-66 between N Veitch St and Spout Run Pkwy.
*happy dance*
August 17, 2016 at 4:24 pm #1057672TwoWheelsDC
Sad face.
August 17, 2016 at 6:15 pm #1057687Vicegrip
Sad face.
And I though it was just me that tried to time them right.
They need a geoengineering company to figure out that the soil back fill under the deadmen links between the upper and lower walls was not properly compacted? The soil settled, the deadmen did not and we get a set of woop de dooz.
August 17, 2016 at 6:19 pm #1057690Tim Kelley
It has been replaced twice in the past 15 years with the same effect, so they want to see what’s going on. I think the issue was discussed at the most recent BAC meeting so there may be more details in the notes.
August 17, 2016 at 6:28 pm #1057692ShawnoftheDread
Are you saying there are bodies buried there? Maybe Jimmy Hoffa?
August 17, 2016 at 6:29 pm #1057693Tania
Did someone say woop de dooz?
[ATTACH=CONFIG]12298[/ATTACH]
August 17, 2016 at 6:59 pm #1057700bentbike33
ParticipantI thought I identified the Custis mogul fix in this post?
August 17, 2016 at 7:11 pm #1057703consularrider
Looks just like the Rio BMX that was on the German Olympic coverage tonight!
August 17, 2016 at 7:59 pm #1057708Vicegrip
My bet, by looking at the structure that was built is the original contractor did not back fill and compact properly or with the proper compact-able fill. In the contractors defense the entire width of the path and likely the entire depth of the wall from the bike path surface to Rt 66 surface was back filled and this was not compact able via large format equipment. That much fill without the dead men and the path would simply settle a bit and the side walls seem to grow. The dead men that tie the upper/inner and lower/outer walls will never move at all so all the soil settling shows up as saggy pants asphalt hammocks.
Tie footers into the inner and outer walls, back fill and compact a bit, pour concrete slabs onto the pined to the walls footers then top with asphalt. Strong, frost resistant and no more saggy hammocks, ever. No worries abut pressure on the lower outer wall and added stress on the dead men. The added slabs don’t need to be VDOT level thickness, would rest on heavy solid existing structures and add very little weight % to the existing structure. I suspect this is a money thing as tied in slabs would cost more that jack hammering the existing surface out, adding yet more dirt and a new bike thin layer of tarmac. Dirt and asphalt are cheap.
August 17, 2016 at 8:22 pm #1057710bentbike33
If I ever get a rock band, I will have a name for it.
August 17, 2016 at 8:28 pm #1057711mstone
Yeah, my thought was that replacing the surface every couple of years is probably way cheaper. Don’t know why they’re even bothering with a study unless 1) they’re concerned the wall is going to collapse or 2) because of wacky government money it’s easier to get a couple million at once than a couple thousand every few years. Luckily I don’t go that way often, so I have no worries about 1).
August 17, 2016 at 8:55 pm #1057713Tim Kelley
ParticipantYes, that’s what they are trying to figure out with this work.
August 17, 2016 at 9:09 pm #1057715TwoWheelsDC
ParticipantI think the best alternate route for when the real work begins would be for the closure of one lane of Lee Hwy and the creation of a two-way protected cycletrack from Lyon Village to Uhle St. Then, when the work is done, everyone realizes that traffic on Lee Hwy hasn’t gotten any worse, so the cycletrack might as well just stay where it is…
August 23, 2016 at 4:47 pm #1057866Steve O
From personal experience, I believe it’s been replaced twice ever, but only once in the last 15 years. In fact, I think the last time was about 12 years ago, give or take.
