Crowdsourced Air Pump Map
Our Community › Forums › General Discussion › Crowdsourced Air Pump Map
- This topic has 21 replies, 14 voices, and was last updated 12 years, 5 months ago by
lordofthemark.
February 6, 2013 at 4:49 pm #912786
ParticipantThere are only a few locations in Arlington and DC. If you know of any other, please add them!
February 6, 2013 at 4:55 pm #961384
americancyclo
Participantare these 24 hour access? Should the local bike shops be on here?
February 6, 2013 at 5:22 pm #961380TwoWheelsDC
ParticipantI added Freshbikes, RevCycles, City Bikes, and Bicycle Space. All the gas stations I’ve used in this area charge at least $1 and you have to have quarters 😡
Edit: Also added the W&OD rest top between Lee Hwy and Little Falls St.
February 6, 2013 at 6:36 pm #961374baiskeli
ParticipantBe very careful putting air in with a powered pump! They work fast. If the pump has no meter, or a meter for low-pressure car tires, you don’t know when you’ve got too much. You can be riding along on the Mt. Vernon trail on your way to work shortly after filling up and then hear a strange rubbing sound and look down and see your tire bulging, and then hear it explode just as you’re desperately reaching down to the valve to let some air out to correct your horrible mistake. Don’t ask me how I know this.
February 6, 2013 at 6:58 pm #961365culimerc
ParticipantThe Bike Lane (Reston), Bike@Vienna, Spokes (Vienna), and Bikenetic all added.
February 6, 2013 at 7:12 pm #961368creadinger
ParticipantShould it also be noted that gas stations probably won’t have the attachments for presta valve stems. Right?
February 6, 2013 at 8:09 pm #961354consularrider
That’s a dead certainty.
February 6, 2013 at 8:18 pm #961349mstone
Participantwho doesn’t carry presta adapters?
February 6, 2013 at 9:47 pm #961336Terpfan
ParticipantI tossed in the Bike Rack on Q (up by 14th). I’ve used it probably a half dozen times as it’s easy for me to loop up to it and circle back around for work. The map could be very helpful with persuading folks for bike to work day. Now, if we could just get one on MVT by airport and maybe one south of OT then I would take my pump off my bike figuring I could walk it to them.
February 6, 2013 at 10:16 pm #961331fuzzy
Learned my lesson when I was 12, scooter & gas station pump, face full if chalk and ringing in my ears.
February 7, 2013 at 12:15 am #961317baiskeli
I don’t. I carry a full bike pump. Because you can be riding along on the Mt. Vernon trail on your way to work shortly after filling up and then hear a strange rubbing sound and look down and see your tire bulging, and then hear it explode just as you’re desperately reaching down to the valve to let some air out to correct your horrible mistake.
February 7, 2013 at 12:20 am #961311mstone
I carry a pump also. But I also carry an adapter, because if I have a pump problem and the other guy’s pump only has a shraeder… You’re only paranoid if murphy isn’t out to get you, and the adapter is like the size of a tic tac.
February 7, 2013 at 12:22 am #961312baiskeli
ParticipantFound this video – looks like the bubble ripped up his rim and ruined his wheel!
http://www.youtube.com/watch?v=AfYCnbrh45k
February 7, 2013 at 12:23 am #961313baiskeli
Good point! I’ll go put an adapter in my bag right now.
February 7, 2013 at 1:15 am #961309Rod Smith
ParticipantFebruary 7, 2013 at 1:21 am #961304 -
