Cold bike problems
Our Community Forums Bikes & Equipment Maintenance Cold bike problems
Viewing 5 posts - 1 through 5 (of 5 total)
  • #1019167
    worktheweb
    I had a similar problem with my front derailleur on Tuesday, what happened was the cables froze into place where they route under the bottom bracket. Even with fenders, I still get some spray from the front wheel down there. When I got home I brought the bike in to let the ice melt and then gave that area a healthy hit of WD-40 to displace the water and make it less likely to return. Worked for yesterday’s ride.
    #1019168
    Let me also add – if you get a bunch of snow all stuck up inside your fenders, and being a lazy person you leave it there and store your bike outside in the polar vortex…it will turn to solid ice and your tires won’t turn at all.
    Don’t be me. Don’t do that.
    #1019175
    Its probably contamination in the cables. Water seeps into the housing over time, and when its super cold, it freezes and prevents the cable from moving. Squeezing the brake lever is doable because your hand is exerting a lot of force, but the return spring on the brake isn’t strong enough to open it back up afterward. Solution is new cable and housing.
    Handlebars are likely the lube or contamination in the headset bearings. Solution is to clean them and lube with a thinner grease for the winter.
    #1019178
    Crickey7
    If your cables are nekkid down there, you can have the next set installed with housings that go around the bottom bracket and part of the way up the tubes. It won’t prevent contamination, but it will reduce it and ensure your cables don’t get caught in a block of ice.
    #1019191
    This happens to me with my rear derailleur sometimes (including this morning). I live up a hill, so my bike is in a low gear when I get on in the morning. The spring wouldn’t pull the frozen cable through, so I couldn’t shift into a higher gear (maybe good for spin class, but not good for actually going somewhere).
    For a temporary fix, you can manually pull the brake open or pull on the cable. Then work it open/shut a few times to see if it will loosen enough to get you where you need to go. With my derailleur I only need to pull it through once to get it working usually.
