C&O: Gravel bike, XC Mountain Bike, or Cyclocross bike?
Our Community › Forums › General Discussion › C&O: Gravel bike, XC Mountain Bike, or Cyclocross bike?
- This topic has 36 replies, 20 voices, and was last updated 8 years, 9 months ago by
KWL.
September 7, 2016 at 6:16 pm #1058576
ParticipantGravel and cross would be more versatile, so going with the mountain bike would be the best option only if you decide you want to get into it. It really is fun, but yeah, mostly you need to drive to somewhere like Wakefield or Fountainhead.
You can also do some light mountain biking with a cross bike. I did the Wakefield trails with my the Bianchi Volpe I used to have by way of training for Monster Cross. It’s jarring and more squirrely, but certainly doable.
September 7, 2016 at 6:45 pm #1058578jrenaut
Participant@Jason 145520 wrote:
Cyclocross bike: not sure if this is any different than a gravel bike anymore, same advantages
I’d be interested in what the difference is. I had always thought a gravel bike was a cross bike with knobby tires. Which is still a cross bike.
September 7, 2016 at 6:49 pm #1058579AFHokie
ParticipantI’ve always thought of cross bikes as road bikes with clearance for knobbie tires and gravel bikes have a relaxed geometry as well as clearance for knobbie tires
September 7, 2016 at 7:05 pm #1058582hozn
My only, and current bike is a Cannondale CAAD10, and that wont work on the C&O.
I think many would disagree with you. I might throw 28mm tires on there, assuming those will fit the CAAD10, but I know folks that ride the C&O on 25mm tires without giving it any further thought (I have only ridden it on 28mm tires).
Sure, it’s true, that if you were to pick the perfect bike for riding on the C&O gravel, it’d probably be a … gravel bike! But often those are the same as CX bikes. Really the only consistent difference comes down to intent: a gravel bike should have road-bike gearing (e.g. 34/50 chainrings) and mounts for fenders. Usually they also sit a little lower to the ground and clear larger tires. I’m not sure if there’s any real difference between a gravel bike and a touring bike — other than marketing.
MTB is certainly overkill for the C&O, but if you actually want to start mountain biking, you could ride the C&O out to the MoCo trail system. I finally got around to doing that route w/ Pete & crew this year and that was a lot of fun. Still, though, it was a long way to ride the MTB and the MoCo trails are pretty non-technical, so a ‘cross/gravel bike with 35+mm tires would probably be a good option for that route.
Full-suspension MTB is definitely overkill around here, unless you’re riding up in Gambrill. But if you’re interested in learning how to mountain bike, don’t get a full-suspension: a good one will be much more expensive than a HT and the HT will do more to teach you about how to ride. Once you start doing the all-day epic MTB rides/races, you might consider getting a full suspension so that you can sit down more. I will admit to missing my full-squish bike this past weekend at the SM100.
So, in short, if you want to use the C&O as an excuse to buy a new bike, get a gravel bike. Otherwise, just throw a set of 28mm tires on your road bike and have fun. And if you independently start mountain biking and want to ride the MoCo trails, then you can use the C&O to get there.
September 7, 2016 at 7:11 pm #1058583KayakCyndi
Geometry is the different between the two bikes. Gravel bikes tend to have longer chainstays and higher head tubes. Many have rack and fender mounts. They are made for all day (or multi-day) riding. A cyclocross bike, especially a higher end race oriented one, is typically going to have shorter chainstays, longer top tubes, lower bottom brackets for cornering and you’re lucky if it even has bottle mounts on it. All day comfort is sacrificed for speed. After all a cross race is usually an hour or less.
Take all that with a grain of salt as there are lots of “cyclocross” bikes that are less racy and more “gravel” style and there gravel bikes totally geared toward racing.
Best advice, go ride and see what you like!
September 7, 2016 at 7:27 pm #1058588Jason
ParticipantThanks Hozn, great advice, but the CAAD10 has ultegra brakes, 25’s BARELY fit. Shimano says 25 is the max, 28’s a no-go. Good advice though, because I AM trying to steer away from an additional bike. I can get a Raleigh RX 2.0 2017 for around $900 (Cross bike, SRAM 1x, TRP Mechanical disks). I already have a spare set of XT MTB pedals from when I commuted, so the only additional investment would be the bike itself. Not sure if being able to ride the C&O is worth it enough to get a seperate bike. Hmmmmm.
September 7, 2016 at 8:07 pm #1058595hozn
If you have sufficient frame/fork clearance for a 28, what about just getting a new set of brake calipers known for better clearance? That should be a small investment, comparatively.
Just throwing it out there. Obviously I want to encourage n+1, though!
September 7, 2016 at 8:07 pm #1058596KayakCyndi
Not sure? That is just crazy talk. Of course the C&O is worth an n+1.
[ATTACH=CONFIG]12379[/ATTACH]
See what you are missing!September 7, 2016 at 8:31 pm #1058598DismalScientist
ParticipantJust do a quick fixie conversion with 28s. Then you won’t need brakes.:rolleyes:
September 7, 2016 at 9:06 pm #1058601JorgeGortex
Hey everyone, I am considering adding the C&O onto my fun/training rides. This topic/question is spanning two areas, where to ride and bike/technical so didnt know where to post it. Thinking of riding the C&O for somewhere to ride that’s just different from what I have been doing (arlington Loop, Beach Drive, ect). Also the allure of being away from any traffic sounds good, at least on paper. I currently ride 2-3 days a week averaging 20 or so miles each ride on the usual Arlington-style hills. My only, and current bike is a Cannondale CAAD10, and that wont work on the C&O. Not sure if its worth another bike for a single trail but considering the following options:
Gravel Bike: allot of new options in this area, would also be useful for a wet weather training bike
XC Mountain Bike: Hard-tail or full suspension? I dont currently mountain bike, but this would maybe open up the occasional mountain bike trail as an option. I have little to zero skill on a mountain bike trail.FWIW I did this ride https://www.strava.com/activities/660267634 on my ’96 Specialized Stumpjumper with tires similar to these http://bike.michelinman.com/tires/michelin-country-rock. (Mine are old and slightly different with a shoulder knob. 26×1.75). I had not done a distance like that, especially off-road, in awhile, and was perfectly comfortable. Plenty of speed, good control, and felt good at the end.
Unless you plan to get into serious mountain biking I don’t think you need full suspension. It would be overkill for the C&O. A used hard tail with sem-slick tires like I used would give good grip and good rolling resistance on that sort of trail. Otherwise one of the new gravel grinder bikes, or like someone else said, a Cross bike with as wide tires as you can stuff it in would work (I did see a couple of those go by me).
If you ever want to ride that route I’d be game. Good luck.
JG
September 7, 2016 at 10:01 pm #1058608Crickey7
ParticipantIf you go the hardtail MTB route, consider getting a 29er. It’s a lot easier to get tires as skinny as 35 on that size wheel.
September 8, 2016 at 12:37 am #1058616peterw_diy
ParticipantWhat hozn said. I’ve ridden the first 10 miles or so on 25c. Doable but you need to pay attention — none of that slacking off like the wimps with suspension forks get away with. I’ve bikepacked the full trail (bag, pad, tent, stove… the works) on 28c, which was undeniably nicer.
September 8, 2016 at 3:08 am #1058627vvill
ParticipantAnother “what hozn said”: For *just* the C&O I would probably just try to shove 28/30s in there!
But for n+1, I guess I would consider whether you might like/enjoy gravel/dirt riding more or MTBing more. Obviously you can ride a MTB on gravel, although it’s a little slower. CX/gravel bike on singletrack is a bit tougher, esp if you’re not great with MTB skills (like me).
There are all sorts of things that go into different bike designs but I can’t say whether they make that much difference. (I simply haven’t ridden enough bikes!)
A CX bike will generally be more aggressive than a gravel/adventure bike (lower stack, longer reach, steeper angles), and have a higher bottom bracket. It only really needs to clear 35mm tires, and is designed for quick handling, stiffness and light weight over comfort, and doesn’t always have rack, fender or even bottle cage mounts. The top tube is sometimes shaped specifically for shouldering and sometimes cables are run over the toptube so they’re not as exposed to dirt/mud from under the bike. It’s probably more similar to a crit road bike really. The trend lately is to have 1x gearing since the gearing range needed in a CX race isn’t that large, but even before that, 46/36 was a common chainring set up. Bikes are weight weenied and tubulars are the norm for competitive racers. Expensive CX tires are a little odd in that they’re so very specific in purpose: CX often has slippery but not sharp surfaces (grass, mud, dirt, sand – sure, but less rocks, roots, gravel) so they’re not particularly puncture resistant, they have smaller knobs and since they’re also made to be light and supple the knobs you need for races don’t usually last long on pavement (nor sharp gravel rides).
A gravel/adventure bike is more similar to an “endurance” road bike but usually with 40mm+ tire clearances. So – more stack, less reach (significantly taller headtubes), longer chainstays and lower BBs. More stable handling, ability to ride longer more comfortably (possibly in aero positions, and in pacelines). Gearing will usually be wider, although with 10-42 cassettes and such nowadays, 1x is popular. Frame shapes can be a bit more varied since there’s no shouldering of the bike – OTOH, fitting frame bags/packs and multiple water bottles is important. Tires need to be tougher through the casing and running them tubeless is popular.
A touring bike will almost always have full fender and rack mounts and the frame/tube shape/sizes will probably be chosen to be a little stiffer/tougher, to handle heavier loads. So it’ll be a heavier frame. It’ll likely have the widest gearing – a triple or double, and touring bikes also tend to use older, burlier components for durability + serviceability: bar end shifters, mechanical discs over hydraulic discs, etc. And steel is the most popular frame material for the same reasons.
Compared to an all-out road racing bike, I think the CX bike was seen by bike manufacturers as the best “speedy” commuter alternative so they were often marketed as dual duty, especially for commuters who liked to dabble in CX and wanted a bike a little less single-purpose than a pure CX race bike. But since “endurance road” and now gravel bikes are their own categories I think there’s a little more consistency in what you might expect out of a bike category… a little more.
September 8, 2016 at 3:12 am #1058628TwoWheelsDC
My Fuji Tread is categorized as a “gravel” bike, but in reality is just a repainted Fuji Cross CX bike. The only differences, as far as I can tell, is the more street friendly tires and compact (as opposed to CX focused) crankset that it comes with from the factory. So yes, many “gravel” bikes are just CX bikes, but there are gravel bikes that have different geometry than their CX counterparts.
September 8, 2016 at 11:50 am #1058633hozn
ParticipantJust to follow up on the idea of 28mm tires, it looks like from this thread http://weightweenies.starbike.com/forum/viewtopic.php?t=104735 that maybe pre-2013 versions of the CAAD10 may not have clearance for 28mm. (But it sounds like there are several reports of people running 28mm tires on the more recent CAAD10 frames, which suggests that if you also have a newer frame it might be simply a matter of finding a set of calipers known to provide a little more clearance. It obviously depends on where the tire is making contact too. And of course measured size is not the same as nominal size; if you have wide rims then a 25mm might be measuring closer to 28mm, etc.)
