Clip less pedals – unclipping
Our Community Forums Bikes & Equipment Clip less pedals – unclipping
  • #910052
    StopMeansStop
    Got a set installed today. I fell 3 times 😮
    What’s the proper way to snap out of these things? My legs look like the electoral map. Spots of blue with vast areas of red.
Viewing 15 replies - 1 through 15 (of 29 total)
  • #927148
    JimF22003
    Rotate heel outwards. That’s about all there is to it. What kind of pedals did you get? Mtn bike style (SPD) pedals are usually a bit easier to clip in and out of, and they can be adjusted so they’re easier or harder to get into and out of. The shoes are easier to walk around in too. I use those on my cross bike. For the road bike I use Look-style cleats.
    Are you physically having trouble getting out? Or do you just forget? That was my main issue for the first couple of weeks. If you physically have trouble getting out that’s an adjustment issue hopefully.
    #927149
    eminva
    You can bring your bike inside and practice in a doorway a few times until you get the hang of it. They say you should start off on grass to cushion your fall, but not all styles of bikes are conducive to that.
    Good luck.
    #927150
    SerialCarpins
    As someone stated above, I don’t know the exact trouble you’re having, but to chime in, like Jim, my pedals have adjustments that can be made to them to be able to unclip a little easier. Yours might have the same thing, and you can maybe adjust them down a little to make twisting out of them a bit easier until you get used to it. Good luck….I had a couple days of trouble with mine, but now I can’t live without them…and haven’t had any trouble since. I even got clipped by a cab, fell off the bike, and my shoes unclipped instantly when I fell…
    #927152
    acc
    Only three? I’m jealous. On the bright side, I fell so often I stopped worrying about falling. Being a big baby I decided to ease myself into the system by staying clipped in on my non-dominant leg first. I kept my other leg free. Once I was comfortable with that arrangement I clipped in my other side when I had plenty of room to ride and not a lot of starting and stopping (intersections or small children). That cut down on most accidental rest stops on the pavement. Finally I got tough and forced myself to deal with it. That may have been last week. :cool:But in all seriousness I had to work out a plan to get used to the system. Being able to anticipate a stop well before it happened was key. Your mileage may vary.
    Happy tails,
    ann
    #927156
    StopMeansStop
    I loosened them up, but Im having a problem with the twisting motion. It feels unnatural. This video suggests pushing the heel down before twisting.
    http://www.youtube.com/watch?v=zLZbijqcjtw&feature=youtube_gdata_player
    #927165
    CCrew
    I just do a quick snap outward of the heel. I know it feels odd at first, but it does become second nature.
    #927167
    StopMeansStop
    How much slack should there be between the cleat and pedal? When I do a twist, I feel some wobble sometimes before it snaps out.
    #927168
    CCrew
    The standard is 6 degrees of float. Some pedals run more few run less. There needs to be a certain amount of slack in the pedal/cleat interface or there’s no give for your knees.
    If we’re talking Shimano SPD cleats here there are also several versions There’s the SH-51 and the SH-56. The SH-51 is black and is a single release cleat. The SH-56 is gold and is a multi-release. the 56’s release in multiple directions and are a bit easier to get to release. The 51’s are twist heel out only and can take some getting used to for a person unfamiliar with them.
    I rarely unclip my left foot. I pretty much always use my right, and have found that the easiest release comes with the crank arm in the 6’oclock or 9’oclock position, it’s where your heel has the most leverage and the crank arm is least likely to spin. Your (and others) experience may vary, but it works for me.. I’ve been doing it so long I’d honestly have to go look any more to see what it is I still do most frequently since it’s become such second nature.
    I also do not wait until full stop to unclip.
    #927169
    Greenbelt
    I loosened mine up as far as possible on my commuter bike, and then squirt chain lube on them for additional slipperyness. (I’m not sure if they’re supposed to be lubed, but so far I haven’t had any trouble. I’ve never accidentally popped out of them while riding, but have been really grateful a few times when I needed to put a foot down fast that it came out so easily.)
    Also, new pedals just sometimes are very stiff. I got some new ones for my weekend bike a couple weeks ago and had a lot of trouble at first (didn’t have a screwdriver with me to loosen them). But after a while, they seemed to loosen up a little on their own.
    #927183
    Eventually this motion becomes second nature. I went through this in the mid 1980s. It brings back fond memories. Hang in there.
    Which pedals did you get?
    #927188
    PotomacCyclist
    View it as a rite of passage. The only way to get comfortable with clipless pedals is practice. The doorway tip is a good recommendation.
    Many beginners forget to lean to the correct side. If you unclip your right shoe as you approach a stop, you have to lean your body to the right as well. If you lean to the left, then you’ll do the slow tip-over. (This is based on what I’ve heard from others. I never had this problem myself. Well, maybe once. Or twice. Or three times…)
    The good news is that once you get used to the pedals, you shouldn’t have many more problems. I had a lot of issues during the first 2 or 3 weeks with clipless pedals. But none since fall 2009. Fortunately, even when you do have issues with the pedals, it only happens when you are stopped or almost stopped at an intersection. It’s unusual to have a problem with the pedal when riding at faster speeds. Normally you wouldn’t be trying to unclip in those situations.
    #927189
    DaveK
    I’ve fallen exactly once in clipless pedals, several thousand miles after I first started using them. I thought I was immune. Then I pulled up to a stop sign outside one of the largest bars in Tampa, FL (and that’s saying something), unclipped on the right, and leaned left. About a thousand people yelling “Nice one, Lance!” really helped encourage better pedal discipline. Haven’t done it since.
    #927195
    eminva
    Thanks — this has been a really informative thread. I knew I needed an adjustment because my knee was yelling at me recently on a long ride. Prompted by these posts, I checked the cleats this morning and one of them must have slipped — it was in a completely different position than I remember putting it. So I guess you should turn your shoes over once in a while to make sure they are okay.
    So, how do you avoid cleats slipping? Put them on tighter?
    Thanks.
    #927202
    OneEighth
    Over-tighten the bolts holding the cleat in place and you may end up shearing them. Like everything else on a bike (or motorcycle, or car, chainsaw, etc.) you just have to perform regular checks. Things just tend to work themselves loose over time.
    #927223
    I also mark the cleat placement on the soles of the shoes so it is easy to see if they’ve slipped.
