chain stuck
  • #919832
    streetsmarts
    so while riding home through Shaw last night in the dark my chain came off / got stuck. i got all greasy trying to unstick it and finally got a bus home.
    this ..or something similar….has happened several times. my LBS has adjusted the derailleurs recently.
    1. should I attempt to fix (meaning undo this mess and put the chain back on) or take to LBS? I do think this time the chain in partly twisted near hangar
    2. is it me…or is something wrong with the derailleur, limit screws, hangar, etc?
Viewing 15 replies - 16 through 30 (of 38 total)
  • #1077802
    n18
    I would say do it yourself, but in a very well let area. Don’t try it too hard, just try another method of one doesn’t work. I would generally try both peddling backward and pulling the chain at the same time.
    #1077807
    Harry Meatmotor
    Sometimes the only way to get a chain that’s stuck like that one out without scratching the crap out of the chainstay or BB shell, or bending links in the chain, is to remove the drive side crank arm. In a shop, that’s a 2 minute job. At home without proper tools, i.e., a crank puller, it’s pretty much impossible.
    #1077811
    streetsmarts
    I was thinking the same thing. So if you see someone drenched and freezing tonight, rushing home and walking the bike to the bike shop – that’ll be me. Prep for Freezing Saddles!
    Also, note to self – if you get a large bike, and put fenders and a rack on it – no matter what car you own/rent or taxi /rideshare you take – it’s not easy to put the bike in it and not easy to transport without messing up the fenders. Little did I know.
    So last I night did bus/Metro… which work. But wish I could’ve done rideshare.
    #1077812
    streetsmarts
    Speaking of….weren’t you talking about some group type classes – for ex. “how to shift”….
    seems like a good idea to me. :)
    #1077813
    streetsmarts
    @Judd 167661 wrote:
    The other thing that I can think of is how you’re shifting. If you’re holding the shifter down for a long time when shifting, this can cause an overshift and a chain drop.
    Weren’t you talking about offering some “learn how to” classes. Like maybe “let’s talk about shifting”. ……
    #1077815
    Emm
    Somebody gave me this book a few years ago. You’re welcome to borrow it if you want to read up on some of this stuff (it has a whole section on shifting I found very helpful.) I found it useful overall, although hands-on-lessons are usually even better :)
    #1077816
    streetsmarts
    Good book. Komorebi lent it to me last year but I didn’t get to read much. I still have a lot to learn. Would love to borrow it again. Thanks!
    #1077820
    Lt. Dan
    Do you have a quick/master link on the chain? If so, you can pop that loose and thread the chain out of there if need be…
    #1077821
    Master link probably won’t do it. Try turning the bike upside down and turning the crank to “unwind” as much of the problem as possible so it is clear where the chain is stuck between (likely) the frame and chain ring. Grab the chain where you can get the most leverage and pull like hell. As with most bicycle repairs, violence is the only solution.
    #1077823
    streetsmarts
    RE whether I have a master link: how would one know this? would one … ask, when the bike shop puts on a new chain? (learning…learning)
    #1077824
    streetsmarts
    Ahh, Dismal!! Violence!!
    #1077825
    bentbike33
    A master link is usually a different color than the rest of the chain’s outer plates. It will also have 2 elongated holes in the outer plates where the chain pins go through. If the two elongated holes are on the same outer plate, you break the chain by bending the chain so the pins of that link go toward the center to the bigger part of the holes. If the elongated holes are on opposite sides (one on each), then you need a needlenose pliers to squeeze the master link open by sliding the pins to the bigger parts of the holes.
    See http://sheldonbrown.com/gloss_m.html#masterlink
    #1077828
    Judd
    Yes, Bike University is a real thing in my head, but not a real thing outside of my head.
    #1077832
    anomad
    Look at what is stamped on your chain, Shimano? Kmc? Sram? If it’s not Shimano there’s a solid chance you have a link that can be removed without tools. It’ll look different than all the other links. Removing and installing a chain is a good skill that you can learn at home with a chain tool and/or knowing how a quick link works. Figure out what you have and spend an hour with it. I’m not in Alexandria for the time being or I’d offer to swing by and help un#uck your chain and give you a few pointers.
    Removing the crank (as suggested) or removing the chain are the best options for serious chain suck. Learning to shift comes with experience and will almost eliminate those issues. But even us old guys screw up once in a while. I did it this summer dropping into my triple and shifting in anger. When mountain bike triple groups were fairly new to the scene it happened all the time.
    I dig the park tool videos if you have some time to spend on YouTube.
    #1077846
    Harry Meatmotor
    BITD:
