Chain Lube
Our Community › Forums › Bikes & Equipment › Chain Lube
- This topic has 26 replies, 18 voices, and was last updated 11 years, 3 months ago by
dkel.
February 28, 2014 at 3:29 pm #994895
OneEighth
ParticipantHose down/clean up with WD-40.
Lube with 3-in-1.
Run a rag between the rollers to clean each link when WD-40 doesn’t cut it.February 28, 2014 at 3:30 pm #994896mstone
Participant@vvill 78580 wrote:
Interesting.
I have one bike I maintain minimally and it’s still on the original (7 speed) chain after over 7 years but only about 1000 miles. Ridden in winter, stored outside. Gets some generic 3-in-1 oil on the chain when it gets squeaky.
Now that I’ve posted this, the chain will snap next time I ride it…
Before I started riding more “seriously”, I knew very little about bikes so it doesn’t surprise me that a lot of people just ride their bikes and nothing else. Growing up riding almost exclusively on cheap X-mart MTBs or cruisers, I would get pinch flats on skinnier tires and still only use a small hand pump to reinflate (insufficiently) as I didn’t own a floor pump, and I never lubed the drivetrain. I knew how to patch/change a tube and that was all.
The chains for lower numbers of gears tend to be a lot more durable than the superlightweight 15 speed wonder-chains (in terms of abuse/low maintenance utility cycling, not necessarily high mile/high performance cycling). Back when I was a kid on a 10 speed (note: not all on the sprocket), I don’t remember anyone ever replacing chains–those things just ran forever. Also, it’s possible for a chain to continue working even after it’s past the point that it’s caused enough wear to the gears that a new chain can’t be put on without also replacing the gears. That said, if the bike is really low mileage, it can go a long time before things start falling off. People sometimes forget that it’s possible for a casual cyclist to only rack up a couple hundred miles per year.
February 28, 2014 at 3:48 pm #994899vvill
Yep, that’s why I mentioned it was a 7 speed chain. I use 7 speed chains on my SS bikes too… 3/32 not 1/8th though
I was a little wary of putting a new rear wheel/cassette without replacing said chain (which I did two years ago), but it’s been fine.
I imagine in the many places in the world where bikes are really just a cheap mode of transportation, chains aren’t lubed much but continue to work mostly satisfactorily.Riding as a kid I can’t imagine any of my bikes got significant enough mileage to require a new chain before they got outgrown.
February 28, 2014 at 4:25 pm #994908eminva
Lube with 3-in-1.
Run a rag between the rollers to clean each link when WD-40 doesn’t cut it.As a WDFC shareholder, I thank you.
Have you heard about WD-40 BIKE?
February 28, 2014 at 5:04 pm #994920ShawnoftheDread
Participant@jabberwocky 77879 wrote:
I used prolink for a while, but a few years back just started mixing my own. 10w30 motor oil mixed 1/3 with mineral spirits. Works about the same, and is considerably cheaper.
.Is that two-thirds oil and one-third mineral spirits? Or 1 part oil and 3 parts spirits?
February 28, 2014 at 5:19 pm #994928jabberwocky
1 part oil, 3 parts mineral spirits. Or more like 2 parts mineral spirits. I’m not super scientific about it, and sometimes mix it a little thicker in the winter anyway (harder to wash off the chain).
February 28, 2014 at 5:48 pm #994939ShawnoftheDread
Thanks.
February 28, 2014 at 6:12 pm #994947Riley Casey
ParticipantLife time supply of exotic super lubes in tiny bottle measured in milliliters VS a gallon jug of the serious stuff. http://www.stihlusa.com/products/oils-lubricants-and-fuels/oils-and-lubricants/chainoil/
February 28, 2014 at 9:03 pm #994966ShawnoftheDread
Is this link safe for work?
February 28, 2014 at 9:10 pm #994967consularrider
ParticipantOnly if there’s no chainsaw massacre.
March 1, 2014 at 4:50 am #994989dkel
Bar and chain oil? I didn’t know I’m supposed to oil my bars, too! I guess that’s what I’ve been doing wrong all this time…
