@jrenaut 151097 wrote:
My chain keeps popping off when I shift up into the big ring up front. What’s the most likely cause or causes? There’s a good chance I need a new crankset and a good chance I need a new chain but I was hoping to approach this a little more scientifically than going to the Bike Rack and asking them what’s wrong. So I’m asking you all.
Seems like maybe your upper limit adjustment is off. On your FD, the screw on the top that is away from the bike is usually the upper limit adjuster. Turning the screw should adjust how far your FD pushes the chain over when you shift. If the screw isn’t adjusted properly, it could be causing your FD to overshift and push the chain off the big ring.
