Bike Rack Recommendation?
Our Community › Forums › Bikes & Equipment › Bike Rack Recommendation?
- This topic has 19 replies, 14 voices, and was last updated 11 years, 7 months ago by
DaveK.
June 27, 2013 at 9:44 am #913641
eminva
ParticipantHello —
We have a new vehicle and are in the market for a hitch mounted bike rack. Anyone have any recommendations? Models to avoid? Thanks very much.
June 27, 2013 at 11:41 am #974064
Hancockbs
ParticipantI’ve had a three bike Saris Axis Aluminum for about 9 months now and like it a lot. It is very light weight and the three straps hold bikes securely. Being aluminum, it does flex a little more that I like, but that is just the engineer in me that over builds everything. If I were to buy it again, I might consider the steel version.
June 27, 2013 at 12:33 pm #974068americancyclo
ParticipantMy brother in law bought the DoubleDown Ace 4 for his American made SUV. It’s held our bikes pretty well for some 6 hour rides and has an integrated lock which is nice if you’ll be traveling somewhere and leaving the car unattended with bikes for a while.
The anti-sway cradles don’t always sit so well on my bike frame, but then again I ride a 61cm.
http://www.yakima.com/shop/bike/hitch/doubledown-ace-4
Just be warned that hitch racks usually disable the backup sensors and add a little extra length to your vehicle, so watch out in the parking lots!
June 27, 2013 at 1:11 pm #974074lim
ParticipantI know you wanted a hitch bike rack, but the closest thing you can get to a hitch is Saris Bones RS trunk rack (if you are at all considering a trunk rack)
It’s got two rubberized metal straps and fit snugly into the back of the trunk, set it and forget it!
It also has a strap that stabilizes the bike closest to your trunk
June 27, 2013 at 1:27 pm #974081mstone
ParticipantWe’ve got a new thule apex 5 that I’ve been happy with so far. The smaller versions have a swing-away option that looks really useful.
June 27, 2013 at 1:29 pm #974082jabberwocky
ParticipantI prefer the wheel-grab style racks (like the Yakima Holdup, which is what I have). Faster to put the bike in and easier to deal with unusual frame shapes.
June 27, 2013 at 1:35 pm #974083FFX_Hinterlands
ParticipantI prefer the kind that hold your bike by the wheels. They are kind of a pain to dial in the first time but they are much more secure. They also do a better job dealing with step-through frames, of which my household has many (including my Dutch bike). Keep in mind that these hitch type racks are HEAVY. Mine weighs a good 60lbs. You may want to spring for an all Aluminum version if you can find it.
I picked up an older version of this rack for $100 on Craigslist:
http://www.etrailer.com/Hitch-Bike-Racks/Swagman/S64665.html
June 27, 2013 at 1:41 pm #974084cephas
That alone sounds worth it. I’m semi in the market for a hitch rack myself. Yesterday I had the bike on the trunk rack (which doesn’t attach so well to the flat back of an SUV), and this morning I discovered my bike rear rack had cracked clear through. I imagine it was from bouncing when it was on the rack. although I can’t imagine, as I thought I’d strapped it down pretty well. At any rate, a stabilizer strap.
June 27, 2013 at 2:30 pm #974093Brent
ParticipantI’ve got a Thule Helium. Holds 3 bikes, is pretty lightweight, locks to the hitch, and includes a built in cable lock.
However, the rubber straps seem to wear pretty badly, I had to replace them after a year.
June 27, 2013 at 2:41 pm #974096dasgeh
Funny you bring this up. We have lots of different style bikes. I had been thinking I wanted a rack like what they have on buses, but didn’t know what they were called. I found a very cheap one on CL ($30, I think) that looks like this: http://www.ebay.com/bhp/bike-platform-rack-hitch
Now that I know what to search for (“platform style bike rack”), I found this cool video review of the options. There are some nice features.
http://www.youtube.com/watch?v=t7CkL1lDA7I
Two questions:
1) Am I dumb to trust our bikes to this cheap one (we use velco straps to keep the bikes on the rack — we strap both wheels, then the frame twice, so 4 straps per bike)?
2) Anyone want to sell a Yakima Hold Up 2?June 27, 2013 at 3:16 pm #974109hozn
ParticipantI have a Raxter Tarsus 1.25 (http://www.raxterracks.com/index.cfm?id=3&prodID=8). It has worked well, very simple with just velcro straps (no need to dial in). Relatively light. On the whole it has done it’s job well. (It gets used at least twice a week and has been on a handful of long trips.)
BUT … two things: 1) the bikes sway around a lot; I don’t care enough to buy the anti-sway bolt thingy, but it is a little disconcerting sometimes and 2) a few (3?) years into owning it now it has gotten pretty rusty I tried touching up with some primer, but that hasn’t held all that well either (that is my fault, I realize). I don’t know whether I would get another one of these, I’d probably consider paying a little more for one of the higher end Thule or Yakima hitch racks.
June 27, 2013 at 5:44 pm #974115FFX_Hinterlands
Participant@dasgeh 56424 wrote:
Two questions:
2) Anyone want to sell a Yakima Hold Up 2?Mine has a rubber coated hook that slides on a riser to hold the frame down onto the wheel holders. It’s very similar to bus racks, but the hook goes on the frame instead of the wheels. I always put straps around the wheels too for long trips, but it’s really gravity holding it down and the straps/hooks keep it from hopping out of wheel tracks.
June 27, 2013 at 6:44 pm #974118dasgeh
ParticipantOh, and I meant to ask whether there’s any rack that will be able to hold a bakfiets…
June 27, 2013 at 6:59 pm #974120grandallj
ParticipantNot sure about when the sale ends, but REI has Thule racks at 20% off right now. If you’re buying new, etc. Disclaimer: I have no affiliation.
June 27, 2013 at 7:10 pm #974121jabberwocky
Look into tandem racks (since the problem, a longer than usual wheelbase, is pretty much the same).
June 27, 2013 at 7:35 pm #974124FFX_Hinterlands
Oh, yes. You can use one of these:
http://www.uhaul.com/Reservations/EquipmentDetail.aspx?model=AO -
