Bike always upshifting
Our Community › Forums › Bikes & Equipment › Bike always upshifting
- This topic has 12 replies, 11 voices, and was last updated 13 years, 4 months ago by
DSalovesh.
January 24, 2012 at 5:24 pm #935006
ParticipantMark Blacknell would probably recommend a slight adjustment of the barrel adjuster on the rear derailleur. Or maybe time for new cables?
January 24, 2012 at 5:53 pm #935007DismalScientist
ParticipantTighten the bolt on the shifter. I assume this is a friction shifter and is not indexed. Even if it is indexed, tighten the bolt. Sometime the bolts have a little swing out piece of wire that allows you to do this without a screwdriver.
January 24, 2012 at 6:08 pm #935008baiskeli
ParticipantDo you hear the chain rubbing?
January 24, 2012 at 6:24 pm #935012PrintError
ParticipantMine do that whenever the shifter cable or chain need replacing. Check both, replace what’s needed.
January 24, 2012 at 6:30 pm #935013JimF22003
ParticipantIf the derailleur doesn’t actually move, it’s probably a worn chain or cassette.
January 25, 2012 at 12:49 am #935016Rootchopper
ParticipantIf your shifter’s cable is routed underneath the bottom bracket, it might be getting hung up on some gunk down there. Check to see if the cable is moving freely. If not, clean the area and lube the chain so that it slides freely.
February 1, 2012 at 3:07 pm #935502Bunjabi
ParticipantThanks for all the replies!
I fiddled with the bolt and looked at the cables. Apparently, all I needed to do was look, because the problem has stopped… for now. Not sure what I did, but it seems fixed.
I’m guessing the cables need a replacement anyway. Chain seems fine, no rubbing; derailleurs working fine as well.
If it starts again (or the chain explodes or something) I’ll apply the suggestions here en force.
Thanks!
February 1, 2012 at 6:05 pm #935523MCL1981
ParticipantMine started doing the exact same thing in October. It would skip or magically shift itself under heavy load such as that of going up a hill. I quite literally feel your pain. It was the cable exhibiting symptoms of being 10 years old, rusty, and stretching. It can’t hold back that kind of force when it stretches instead of holding.
February 3, 2012 at 4:08 pm #935677Bunjabi
ParticipantUpdate!
This morning (2/3) it started again, but this time with the other gear set (front). I have a feeling the temperatures have an effect on the cables (contracting in cold weather?). We’ll see how the ride home goes.
February 3, 2012 at 7:00 pm #935689CCrew
ParticipantCables really should be changed about once a year.
February 3, 2012 at 8:00 pm #935700consularrider
ParticipantFebruary 6, 2012 at 5:25 pm #935802DSalovesh
ParticipantI had this once.
Everything seemed fine on the stand, on little test rides, and even most of the time just riding around. But whenever I had to start fast after a light or climb a hill things would go all wonky.
I didn’t figure it out until I took the wheel off and parts started shifting around: I had a broken axle. It was an old frame with 120mm dropouts and the narrowest hub I could get my hands on was 126mm. I had no trouble springing the frame apart to mount the wheel, but the extra stress and my city riding (plus a lot of weathering) had split the axle. The skewer kept everything more or less in place except in hard riding conditions, and I live with the problem for several months before I stumbled onto the answer.
Not sure any of if this applies to you, but it’s quick and easy to check.
