Beltdrive Internal Gear Bikes
Our Community › Forums › Bikes & Equipment › Beltdrive Internal Gear Bikes
- This topic has 17 replies, 11 voices, and was last updated 7 years, 6 months ago by
Starduster.
December 14, 2017 at 3:03 pm #1079471
ParticipantI love my Breezer Beltway Infinity, but they don’t make it anymore. Breezer does still make the Beltway line, but with different hubs.
I bought it as my “no excuses” bike. No “I can’t ride today, I need to lube my chain”, no “I can’t ride today, I forgot to charge my headlight”, no “I can’t ride today, I need to adjust my brakes”.
I just get on and go. Occasionally I put it air in the tires. It’s awesome.
December 14, 2017 at 3:13 pm #1079451Joe Chapline
ParticipantI have two bikes with belt drive and internally-geared hubs. I don’t expect to go back to a chain and derailleurs. I made the switch after I had taken my chain-drive bike to two different shops, once to one shop and twice to the other, and the chain was still slipping on the gears. I was also tired of ruining my (office) work pants with grease. The cleanliness of belt drive is a little exaggerated. They’re much cleaner than greasy chains, but they still get road dirt on them. Also, there may still be grease on the outside of the bottom bracket, kickstand, and other parts of the bike. You might want to check whether your bike shop will work on the drive train. A downside I’ve found is that not all bike mechanics are familiar with internal hubs. I was tempted to buy a Priority Coninuum with NuVinci hub, but I really don’t need a third bike. You might want to take a look, it’s the best price I’ve seen: https://www.prioritybicycles.com/products/continuumonyx . I have a Shimano 11-speed hub, I’ve suspected that the 8-speed would provide plenty of gears for me, but haven’t tried it, or the NuVinci.
December 14, 2017 at 4:26 pm #1079473FFX_Hinterlands
ParticipantI have a commuter bike with a Shimano nexus 8 speed hub and a chain. The hub works great, but be careful to angle the shift cable housing uphill from the hub. Otherwise it collects water and will freeze up. I’ve used 3 speed hubs for years and the 8 speed is a big improvement. My next bike will have a Pinion Drive and a belt, I think.
I ride in rain/snow/etc so don’t like having a naked chain. I’ve tried chainguards and even a hebie chainglider. The chainglider doesn’t really keep gunk off of the chain or your clothes. A full chainguard keeps your pants clean but still lets gunk spin off your wheels onto the chain. t I think the only thing that will really help preserve a chain is one of those fully-enclosed Dutch chaincases. You can’t get them here and they make any tire/wheel removal a total pain. So for me a belt would be appealing. The grass is always greener.
December 14, 2017 at 7:25 pm #1079485LhasaCM
ParticipantI was happy with my Breezer Beltway 8+, though it didn’t seem quite rugged enough to stand up to the daily abuse of my weight/pulling the trailercycle/etc. Their externally bearing bottom bracket was almost impossible to get uncreaky. Since you’re in Germany: I’ve been really happy with my Rose Activa Pinion Pro, but that’s probably overkill for a crappy weather commuter bike (at least at current prices). Rose does have different drive train options on that line, but still seems to be quite a step up pricewise from what you identified (I think they start with the Alfine 11, but they may only offer the belt by default with the Rohloff and Pinion models).
Only other comment I’d have: not sure how the 8 speed Nexus hub is, but my wife has a 3 speed, and while it works fine, I found it quite laborious the few times I’ve ridden it. Shifting seemed to take forever (in that there was a noticeable lag between selecting a gear and having that gear actually change), so something to be aware of when test riding it.
December 15, 2017 at 3:37 am #1079495dkel
ParticipantI built up a Soma Wolverine with a belt drive and a Shimano Alfine 8, and it’s my main commuter. Not having to care for a chain is really great, but I do feel I can’t be as carefree with shifting or as aggressive with riding as I might be with a chain drive and derailleur system. The trade-off is worth it for me for commuting, but YMMV. Some criticisms of my current system are:
1) the Alfine 8 hub has a clutch mechanism that engages between gears 4 and 5, which I find to be—very occasionally—alarmingly sluggish when upshifting: the thing has a couple of times almost bucked me off when the clutch just lets go, but I pay attention now, and I am rarely taken off guard anymore (again, YMMV),
2) mostly, the belt is serenely quiet, but it does get gritty and start to make a squelching sound that annoys me; a spritz on the front pulley (it’s not a chainring if there’s no chain!) from the water bottle fixes that quickly—but only temporarily,
3) the hub service is infrequent (once a year at most, for me), but is either expensive, or a pain, or both; I do it myself (because I’m like that), but the transmission fluid was $70 for a small container; it can be used many times, so it works out to be cost effective when compared against $40 or more for a shop to do the job once; that said, I have to take off the disc rotor, and then disassemble the entire shift mechanism from the drive side (stupid snap ring!), which is no small task, and the transmission fluid is nasty and vile,
4) unless you are running straight bars, shifter options are extremely limited: for my drops, I had to get a Jtek bar end shifter that is way cool, but also not cheap and only available from the U.K., which adds to the cost; I think the hub manufacturers assume if you are interested in IGH, you are also interested in maximizing a comfortable, “city” riding position over any kind of road performance (#lazy).tl;dr Belt drive commuting rigs are awesome and bombproof weather-wise, but they trade any high-end performance for their overall ease of maintenance.
December 15, 2017 at 3:47 am #1079496dkel
Participant…aaand here’s a gratuitous pic:
[ATTACH=CONFIG]15896[/ATTACH]
(I do have in mind a plan to build a dynamo wheel to make the bike completely, awesomely ridiculous.)
December 15, 2017 at 2:28 pm #1079484FFX_Hinterlands
Dynamo wheels are a game changer in the winter. Cold and battery-powered lights don’t mix very well. I have daytime running lights on my front light as well that I run all summer.
I got my dynamo wheel for cheap shipped from Germany (where they require lights on bikes): https://www.taylor-wheels.com/catalogsearch/result/index/?laufrad_groesse=56&q=dynamoDecember 15, 2017 at 3:26 pm #1079504Sunyata
ParticipantI have a Raleigh Misceo 4.0 built up as a belt drive with a Shimano (ugh) Alfine 11. The hub requires a little more maintenance that I would like (but I mean, honestly, it is not much, it gets taken apart and rebuilt at Bikenetic once every 18 months or so), but other than that, I put air in the tires every once in a while and change out the brake pads every 5,000 or so miles.
I am terrible at remembering to rinse off chains after riding in snow and ice (and the road treatments that come along with that) or lubing chains on a regular basis. The belt drive and IGH have been instrumental in me not having to replace shifty bits on a regular basis.
I have over 10,000 miles on the bike and am just now starting to think about replacing the belt. It does not show any wear, but I would rather replace it sooner rather than later when it breaks on me when it is -5F and windy on my way to work.
December 19, 2017 at 1:04 pm #1079599FFX_Hinterlands
I got my dynamo wheel for cheap shipped from Germany (where they require lights on bikes): https://www.taylor-wheels.com/catalogsearch/result/index/?laufrad_groesse=56&q=dynamoOK, Taylor Wheels of Germany no longer ships to the US. Gah. Thanks, Trump!
December 21, 2017 at 10:14 am #1079698dplasters
ParticipantI was a fan of my two belt drive bikes but I ended up selling both of them and now have a 1×11 regular chain powered doohickie.
As some have mentioned, the cleanliness of the belt can be slightly overstated, though the lack of maintenance is 100% spot on. I would ask for a demonstration/tutorial on rear wheel removal/tensioning on whatever model you are looking into and consider it a major factor in what you purchase.
Some companies have very clumsy systems that require a lot of work to get the tensioning back/wheel on correctly, while others have some amazing designs that are much simpler to get the rear wheel back in just the right place. Also, rear wheel flats can be a pita.
December 21, 2017 at 3:44 pm #1079703chris_s
^^^^ This.
I’d been meaning to come back and post again to point this out, but dplasters has handled it beautifully. Belt tension is important. All of these bikes have a way to get the belt through the frame. Some of them make it really easy to get the wheel back on with the exact same belt tension as before, others make it nearly impossible. I’ve heard really good things about Spot‘s design, for instance.
December 21, 2017 at 4:55 pm #1079712LhasaCM
Participant@chris_s 169880 wrote:
^^^^ This.
And THIS was why in the end I couldn’t stand the Breezer long term, as it tensions not through sliding dropouts like Spot, my new bike, or (I believe) the Soma frame, but through and eccentric bottom bracket. And even though it shouldn’t, changing the tire always got the tension out of whack and required adjustment.
Sent from my ONEPLUS A5000 using Tapatalk
December 21, 2017 at 5:17 pm #1079716drevil
Why did you have to readjust the EBB after a wheel removal? I have a few EBB bikes, and I don’t need to adjust the EBB every time I take off the wheel. Is it the belt that makes things wonky?
December 21, 2017 at 5:49 pm #1079714LhasaCM
On the Breezer, it was an externally bearing bottom bracket. So I think that particular design was problematic for a number of reasons. I don’t think it was a belt-specific issue and may just have been me and my bike. However, a more common EBB design wouldn’t have had the same issues, I believe.
December 21, 2017 at 8:40 pm #1079723dkel
The Soma has vertical dropouts that slide in the frame, which means that you can set the tension by sliding the dropout, and then lock the dropout in that position such that when you remove the wheel it goes back into exactly the same place it was before. The disc caliper slides with the dropout as well, so there is no readjusting the brake every time you remove the wheel—or even when you have to slide the dropout.
