Anti-ninja deer-buster two-wheeled sunrise – Phase 1 completed!
- This topic has 36 replies, 17 voices, and was last updated 13 years, 6 months ago by .
I finally have phase one of my anti-ninja deer-buster two-wheeled sunrise completed. My goal with this was to use my existing knowledge and skills with automotive and emergency vehicle equipment and control on my bike to provide:
– Super bright headlights
– Super bright flashing lights for the road
– Dim flashing lights for the trails
– All on one control panel
– All on one rechargable battery pack
– All for less money than buying actual bicycle lights that do the same thingWhat I wanted to avoid at all costs
– Multiple different batteries to change or charge
– Buttons on every device all over the bikeThis weekend with the help of one of my friends that is equally as crazy as me, everything except the dim trail lights is complete! I took it for a ride on the CCT and back roads of Bethesda tonight in the dark and it was INCREDIBLE! The headlight is a 12 watt LED flood light for off-road trucks. The flashing LED’s are all emergency vehicle LED’s. I wish I had a video camera that worked well at night.
Video
http://www.youtube.com/watch?v=opyhoQaDuhkMAIN DEFLECTOR ARRAY
The switch panel, headlight, and the amber flashing light are mounted to a “precision customized mounting system”.Tactical Controller (Mr Worf is off camera…)
Top left switch: Headlight On/Off/Flash
Top right switch: Front flasher Bright/Off/Dim
Bottom right switch: Rear flasher Bright/Off/Dim
Bottom left switch: Spare for future use (possibly for core eject?)Aft phaser bank
This is the rear flasher. If you can’t see me in front of you, then you’re probably asleep at the wheel. This is Way too bright for trail use but definitely gets the point across on the roads.Lithium battery-in-a-bottle
Provides 12 volt power to everything!
