Advice on a stronger rear wheel
Our Community › Forums › Bikes & Equipment › Advice on a stronger rear wheel
- This topic has 12 replies, 9 voices, and was last updated 8 years, 1 month ago by
Crickey7.
May 12, 2017 at 6:07 pm #1070738
Tania
ParticipantVelocity Ailerons. These were recommended to me by Dirt who’s 6’4″ and definitively on the north side of 200#. He uses them on his gravel rig so they’ve seen lots and lots of hard miles. I have them on my commuter but I’m almost half Dirt’s size.
http://www.velocityusa.com/product/rims/aileron-622
I’m a bit of a wheel junkie.
May 12, 2017 at 6:15 pm #1070739bentbike33
ParticipantI got my last wheelset from http://www.prowheelbuilder.com/ because I wanted a generator hub and wanted the rear rim to match the front. They have a huge selection of wheel components with good prices. The online tool asks questions about your bike/body/riding habits, etc. to make recommendations for combinations.
May 12, 2017 at 6:21 pm #1070740hozn
Participant@Overtone 159985 wrote:
This week, a spoke broke on my rear wheel for the third time. The bike is only a year and a half old. Clearly my riding style exceeds the design parameters or perhaps the manufacturing quality of this wheel. Also, Zack at the Velocity Co-op in Alexandria, who was incredibly helpful and taught me how to replace the spoke and true the wheel (yay Velocity!), said I probably would only get another couple months out of the wheel. Three strikes and you’re out.
It’s very possible, perhaps probably, that your current wheel is just poorly built. If tensions are not even, you’ll have spokes break but it’s very possible that this is only happening because of the build and not the load. I’ve had multiple spokes break on a wheel and then rebuilt the wheel w/ same specs and never had a spoke break. Not saying you don’t want a stronger wheel just-in-case, but it sounds like the problem is the build and not the specs.
I use 28-spoke builds for commuting and cx/gravel/dirt riding; I weight ~180lbs these days, so 190-200lbs with backpack on commute. I haven’t broken a spoke in many years now.
I think I probably want a touring wheel. I commute with a heavy computer in a rear pannier, also I’m interested to do self-contained bicycle camping maybe one trip a year. I’ve never bought a wheel separate from a bike before. So I’ve got some questions. Any advice?
1 Adventure Cycling Association recommends (https://www.adventurecycling.org/default/assets/resources/selectingwheels.pdf) a hand-built wheel, 36 spokes, 3-cross. Is that overkill for a rear wheel for loaded commuting+occasional touring?
2 My bike has shimano center-lock disc brakes. Any suggestions for a nice strong disc-specific rim?
3 Are there other factors that strongly affect cost that I should figure out before selecting a builder?
4 Is there an advantage to buying from a local builder? If so who would you go to?
5 If mail-order is OK, which builders are the solid-quality, get-what-you-pay-for-but-not-fancy, an-extra-100-grams-is-not-a-worry trusted names?In case it matters, I’m 160 lbs. Total load might reach 190-200 lbs on a camping trip.
Maybe if I get a good recommendation on #4 or #5 I don’t need to worry too much about #1-3, because the builder will advise me.
1. That’s hard to say, but I imagine 32h would be sufficient.
2. Your current hubs shouldn’t need to dictate the wheelset, other than it’ll need to be disc-brake obviously. Nothing wrong with looking for other CL hubs, though. What kind of bike is this / what diameter rims / what size tires? I am impressed by the DT Swiss R460db rims I’m using now; they are really affordable too. For durability I’m a fan of Hope hubs; they’re relatively affordable. But my next build will be on Novatec, because they’re cheaper, easy to service, and I suspect will prove to be plenty durable.
3. Hubs are a huge variable in the cost equation. From Novatec hubset which are just under $200 (for ones with the good bearings) to Chris Kind which are a few times as much. Or something like Hope in-between at around $300 for the hubset. Spokes can also be a significant variable, but only if you consider at boutique spoke options like CX Ray ($3/spoke vs. the $1-1.50/spoke for top-end, butted-but-non-bladed spokes).
4. Perhaps, though a good wheelset won’t need any maintenance, so having someone local may be less valuable than it sounds.
5. I build my wheels, but If I were going to buy a handbuilt wheelset, I would buy it from November. I suspect that other larger, but-still-building-them-by-hand names like Boyd (their Altamont wheels seem nice) would be good too. Having had bad experience, I would not trust buying a hand-built wheelset by some unknown shop (e.g. on ebay).May 12, 2017 at 6:29 pm #1070742hozn
ParticipantYeah, for disc-brake rims I would recommend considering:
– Velocity Aileron, like Tania said. From knowing folks like Pete run these.
– Kinlin XR31T. I’ve built a couple of these; they seem very nice.
– Flo30. I’ve had a set for a few years with lots of miles on them. Heavy rims, but feel fast and built like tanks.
– the new AForce 33 rims. From what I hear.
– DT Swiss R460db. I’m riding these now; they seem very solid and the tubeless experience has been fantastic.And the new H+ Son Hydra rims look pretty awesome too: http://www.bikehubstore.com/h-plus-son-hydra-p/hydra.htm
I really like Stans Grail rims, but I have to conclude that they’re very easily dented rims. But their tubeless performance is excellent. I’ll probably build another set of these for myself someday.
My next wheels will be these: http://bdopcycling.com/DIY%20Alloy%20Road%20Disc%20Kit%20III.asp (I have a set backordered)
May 12, 2017 at 7:01 pm #1070747Lt. Dan
ParticipantAnother vote for Velocity wheels- broke several spokes on the stock wheel for my Fuji- switched to a Velocity and haven’t had any issues in two years.
May 12, 2017 at 7:27 pm #1070751trailrunner
ParticipantWheels should last longer than two years, unless you are completely abusing them. Your combined weight isn’t that much. I weigh that much by myself.
I’ve built a some wheels with Mavic CXP33 rims. I have two wheel sets with CXP33s and Chris King hubs, and have ridden over 10k road miles on each wheel set. They are still going strong.
May 12, 2017 at 7:31 pm #1070752Overtone
ParticipantWow, great advice from everyone already in the middle of the work day! I’m grateful and impressed. Some awesome leads to check out.
It’s a gravel bike, a GT Grade X 2015. The wheels are 700c (not sure that’s the measurement you asked about). I’ve been comfortable with 28mm tires for commuting. Don’t see any need to go narrower. Could imagine switching to wider ones for doing something like C&O Canal.
John
May 12, 2017 at 7:38 pm #1070753FFX_Hinterlands
ParticipantI ordered a front dynamo hub wheel from Taylor Wheels in Germany. It arrived in a little over a week and was built on a ZAC2000 boxed rim, 36 spoke it is very sturdy. Germans use bicycles more for transportation, so they have tons of more no-nonsense items there (read – more sturdy and heavier for commuting). It’s a factory made wheel so it’s less expensive then having one hand built here. https://www.taylor-wheels.com
May 12, 2017 at 7:55 pm #1070755Overtone
I agree. My previous bike went 5 years and never broke a spoke. I don’t think I abuse the wheels.
I bought this bike from Performance. I spoke to the guy at Performance this week after the spoke broke. He said “you should get a machine-made wheel like that checked and the spokes properly retensioned right after you buy it.” Wish they’d told me that when I picked up the bike.
John
May 12, 2017 at 8:11 pm #1070756trailrunner
ParticipantI’ve had mixed experience with wheels. I taught myself to build wheels a long time ago, and have built wheels for me and for some friends. Once I’m finished building a wheel, they stay pretty true and last a long time. However, I’m slow, and take my time. A good, experienced wheel builder could probably build a wheel in 1/5 the time it takes me.
One of my wheel sets was built by Colorado Cyclist. Even though I know how to build wheels, it was cheaper to select the parts and have them build it. That wheel set was built well and has lasted a long time.
I’ve bought almost every one of my bikes from local shops. One bike didn’t turn out so well. I didn’t want the wheels that came with the bike, so I had the shop build me a set. It was a pretty standard combination of components, and nothing exotic, but they botched it. The wheels wouldn’t stay true and the spokes wouldn’t hold tension. I wound up de-tensioning the wheels and completely re-tensioned them myself. Since then, they have been rock solid, and that was 2003 or 2004. (That particular shop, which has a good reputation, botched a lot of things on that sale, which is why, even though they are only one mile from my house, I won’t shop there again. But that’s another story.)
The only time I’ve had a wheel fail in under two years was when the freewheel on a Hugi hub broke.
May 13, 2017 at 2:22 pm #1070763mstone
ParticipantMy utility/touring bike has 36 spokes 3 cross built on a DT Swiss TK540 rim. It’s been pretty bombproof pushing toward 300# with camping load + kid in tow. (Thank god they’re old enough to ride alone now.)
May 13, 2017 at 6:46 pm #1070766Crickey7
ParticipantI’m with Hozn. Poorly built wheels will act just like. I would also say that once you start getting multiple spokes breaking, that wheel is probably unsalvageable.
