Advice needed: Should I switch from 2X10 to 1X11 on a touring bike
Our Community Forums Bikes & Equipment Advice needed: Should I switch from 2X10 to 1X11 on a touring bike
  • #917592
    bluerider
    As some of you know, I built a custom Salsa Vaya a couple of years ago. It has a SRAM X9 mountain bike group on it geared at 42/28 double crank and a 12-36 cassette. The full build is here. THIS IS NOT A MOUNTAIN BIKE. The bike gets a lot of use and will need some drivetrain attention relatively soon so I am thinking about taking advantage for this future maintenance to upgrade. I like this setup a lot with the exception of the front derailleur. I have had issues with chain suck and jammed drivetrains over the last few months. It has been recently tuning and dialed in as well but the front of the drivetrain continues to be somewhat problematic.
    This hasn’t been a huge deal because the bike generally stays in the big ring except for the worst hills or when fully loaded. But its annoying and I have been tempted to transition to one of SRAM’s new 1X11 mountain bike groups such as GX or X1. My White Industries hub will accept the XD freehub body to install the 10-42 cassette and I can easily use the mountain bike trigger shifter with a Paul mount. Here is the thing: I see lots of reviews online for cross and mountain bikes but not much in terms of touring style bikes with any load. This bike functions as a commuter, loading tourer on pavement and gravel. It has done the GAP/C&O with 60 lbs. of gear. The bike weighs about 28-30 lbs unloaded I’d guess including full front and rear racks with fenders. It pedals along at 27-28 mph without much trouble and the gearing to low enough to handle pretty much anything loaded. But I hate the derailleur and simplifying is a good thing. So is considering a 1X11 setup on a bike like this a mistake?
    I want to stay with a mountain bike group for the durability and my bike is already setup for it. So, considering SRAM GX or X1 with 34 or 36 tooth crank and the 10-42 cassette. In this scenario, I would change to whole group set: shifter, rear derailleur, cassette, freehub and crankset. As long as I can pedal along on 20-25 mph I’ll be happy.
    Has anyone done this? Should I ditch the front derailleur? Any advice? Too big of gaps between gears with a bike like this? Will I be walking up hills?
    Thanks in advance.
Viewing 15 replies - 61 through 75 (of 81 total)
  • #1090947
    peterw_diy
    @ginacico 182379 wrote:
    I can’t afford to be a gear masher. Spin to win is equivalent to knee preservation, and I’ve been really spoiled by triples.
    So why not keep using triples? Yes, they’re unfashionable, but so what?
    #1090948
    Emm
    Like paint colors…. ¡Ay, caramba!. No I don’t want to crowdsource that one. :p
    Your bike should be pink.
    #1090949
    Judd
    @DismalScientist 182376 wrote:
    You know, if you just used shift levers, none of this would be a problem.:rolleyes:
    Wait a minute… I thought you said that more than one gear was unnecessary.
    #1090950
    honestmachinery
    Triples are mostly out of stock, at least at prices I want to pay. I’m still trying to use them, but am reaching down into steel chainring square taper territory lately. Wish I had picked up several Deore trekking sets when they were 50-75 bucks.
    #1090951
    Judd
    Yeah. Keep the easy decisions easy. Except it should be orange.
    #1090954
    They do Rohloff drives too, not sure how they solve shifters for drop bars.
    Co-Motion makes one of the better shifters that will operate a Rohloff hub on a drop bar. It’s a rotating sleeve that slides up next to the stem. Just reach over and click it forward or backward.
    #1090956
    Anyone who has seen my Wolverine knows that orange is already taken. :rolleyes:
    #1090958
    Judd
    Your Wolverine is Exhibit A that orange is the best color for a bike.
    #1090972
    ginacico
    It’s not an option unless I want to buy the frame and build it myself. I’ll be happy with an Ultegra double if it’s the right gear range. Still working out whether CoMo will jigger their stock setup for me, or if I’ll do that myself later.
    “Orange” is way too general for these folks, the question is WHICH orange? Emm, they did just add a new pink. Alas…. mine will be neither of those.
    #1090990
    Glitter is nice. Looks great on my purple Straggler…hmm…I haven’t ridden that bike in a while, now that I think of it.
    #1090994
    n18
    I am a big fan of internal gear hubs with belt drives. The biggest deterrent for drop bar users is that Rohloff hub comes with twist shifters, but according to the article below, there is an after market part that allows Rohloff hub to be used with drop bar shifters and any other shifters. The catch is that you won’t be able to use all 14 speeds, just the same number as the shifter supports, and you wouldn’t need Ultegra when 105 has the same speeds.
    https://www.cyclingabout.com/gebla-rohbox-road-mountain-shifters-with-rohloff-hubs/
    Here is the part that they talk about:
    http://rohbox.com/
    And where to buy it in the US($253):
    https://www.cyclemonkey.com/gebla
    #1090996
    Starduster
    I test-rode a road bike with internal transmission (Pinion or Rohloff? I forgot which one…) at Bikenetic a couple of years ago. Loved the utter simplicity of a single shifter for the entire range. This drop-bar bike had a twist shifter on the bar end, but one adapted from a flat bar setup. As such, it had rather pointy edges transitioning to the bar. Were it mine, I would’ve taken a file to it. I will trust that someone has resolved that complaint by now.
    #1091004
    alternatively, consider trekking bars (which can use flat bar shifters) but still offer a lot of hand positions.
    #1091010
    Yes. Just cleaned it today (for the first time ever, believe it or not).
    [ATTACH=CONFIG]18547[/ATTACH]
    #1091012
    Judd
    [emoji7][emoji7][emoji7] That’s a good looking bike.
