Advice needed: Should I switch from 2X10 to 1X11 on a touring bike
Our Community Forums Bikes & Equipment Advice needed: Should I switch from 2X10 to 1X11 on a touring bike
  • #917592
    bluerider
    As some of you know, I built a custom Salsa Vaya a couple of years ago. It has a SRAM X9 mountain bike group on it geared at 42/28 double crank and a 12-36 cassette. The full build is here. THIS IS NOT A MOUNTAIN BIKE. The bike gets a lot of use and will need some drivetrain attention relatively soon so I am thinking about taking advantage for this future maintenance to upgrade. I like this setup a lot with the exception of the front derailleur. I have had issues with chain suck and jammed drivetrains over the last few months. It has been recently tuning and dialed in as well but the front of the drivetrain continues to be somewhat problematic.
    This hasn’t been a huge deal because the bike generally stays in the big ring except for the worst hills or when fully loaded. But its annoying and I have been tempted to transition to one of SRAM’s new 1X11 mountain bike groups such as GX or X1. My White Industries hub will accept the XD freehub body to install the 10-42 cassette and I can easily use the mountain bike trigger shifter with a Paul mount. Here is the thing: I see lots of reviews online for cross and mountain bikes but not much in terms of touring style bikes with any load. This bike functions as a commuter, loading tourer on pavement and gravel. It has done the GAP/C&O with 60 lbs. of gear. The bike weighs about 28-30 lbs unloaded I’d guess including full front and rear racks with fenders. It pedals along at 27-28 mph without much trouble and the gearing to low enough to handle pretty much anything loaded. But I hate the derailleur and simplifying is a good thing. So is considering a 1X11 setup on a bike like this a mistake?
    I want to stay with a mountain bike group for the durability and my bike is already setup for it. So, considering SRAM GX or X1 with 34 or 36 tooth crank and the 10-42 cassette. In this scenario, I would change to whole group set: shifter, rear derailleur, cassette, freehub and crankset. As long as I can pedal along on 20-25 mph I’ll be happy.
    Has anyone done this? Should I ditch the front derailleur? Any advice? Too big of gaps between gears with a bike like this? Will I be walking up hills?
    Thanks in advance.
Viewing 15 replies - 31 through 45 (of 81 total)
  • #1041892
    bluerider
    @hozn 128730 wrote:
    Interesting — so SRAM 11sp road interchanges with mtb parts? I thought that was limited to 10sp, but am happy to learn otherwise.
    Hmmmmm…..I may need to dig a little deeper into that one.
    #1041893
    bluerider
    Nope, you were right. SRAM changed that with 11 speed groups. Looks like I need to use a Rival 1 or Force 1 long cage derailleur.
    #1041900
    That is too bad, but at least SRAM does have a full range of road 1x componentry.
    #1041901
    Raymo853
    I would be worried about a SRAM 11 speed 10 tooth cog on a touring bike when covered in ice and dirt. Maybe I am too much of a retro-grouch, but I do not even think 11 tooth cogs (Shimano, SRAM, Campy of whomever) belong in such environments. Too much tendency for stuff to build up on that small of cogs and render them un-usable.
    #1041896
    GovernorSilver
    @bluerider 128729 wrote:
    I settled on the SRAM 10-42 cassette. At this point, I am deciding on the front chain ring ratio. At the moment, I am leaning towards a 34 tooth ring.
    Interesting thread.
    The Kona Private Jake that I test rode comes stock with a 40T chain ring as part of its 1×11 SRAM drive train. Climbing on it took more effort than the other test bikes though, because its largest rear cog was 32T. I would have loved to try its brother the Kona Rove ST, which also has a 1×11 drivetrain and 40T chainring but with a 36T as the largest cog.
    #1041906
    ginacico
    @Raymo853 128694 wrote:
    They are freaking dirt cheap since nobody can stand the fashion shame of using triples anymore.
    I’m embarking on a project to swap a Campy racing double for a triple, on my 2001 Univega. Judging by the cost of parts to do that conversion, Campagnolo is unfortunately still the exception to that rule. :rolleyes:
    If anyone has a gear-inch spreadsheet they’d like to share, I’d appreciate it. Cuz math is fun, and would help justify or disprove this effort. Thanks!
    #1041908
    GovernorSilver
    Here’s the Sheldon Brown gear calculator – includes cassettes by Campagnolo as well as the other big makers – even includes internal gear hubs.
    http://sheldonbrown.com/gears/
    #1041918
    I am guessing that when the 10/11-tooth cog are covered in mud and/or ice, those probably aren’t the times you’re needing to pedal above 25mph … ?
    I’ve never head any issue with 11-tooth cogs on the cx bike. Even in very wintery or muddy conditions. (But similarly, I’m not sure how often I’ve actually looked to use that cog in those conditions.)
    #1041921
    Raymo853
    Attached is my spreadsheet. It is a ZIP file that should expand to a normal everyday Excel file.
    [ATTACH]10158[/ATTACH]
    #1042023
    ginacico
    Thank you to GovernorSilver and Raymo853 for the gear calculators.
    The result was a no-brainer, I’ll be switching my Campy double for a triple because the range is much greater. I figure since I’ve already ridden the bike for 15 years, I want to do this once and keep it forever.
    Spent yesterday getting advice on component compatibility from Campy techies on Bike Forums, then went shopping on eBay. After all the parts come in, I’ll let my LBS do the build and tune-up so it all works correctly.
    See what you started, bluerider? :D
    #1042028
    Ya know, if you just change to friction shifters, you wouldn’t have these compatibility issues.
    #1042030
    Wait, will friction shifters work with Di2? Next you’ll be advocating a system that presses rubber blocks agains the rim to stop the bicycle! ;-)
    #1042044
    peterw_diy
    Campy deserves credit here for supporting triples well. Even the Veloce brifters you can get from the UK for under $100 shift triple FDs. None of that Shimano craziness of different shifter SKUs and supply/demand driving availability down and prices up for the triple shifters.
    #1042052
    ginacico
    Concur, this was a fairly easy project. My shifters will work, basically I just needed the triple crank itself, two derailleurs, and a longer spindle. I could’ve gotten away with a “triplizer” chainring set, but went with Campy components to keep the original aesthetics of the bike. With a little guidance to stick within the time period (early-2000s era Campagnolo), stuff wasn’t hard to find.
    Ain’t no retro like khaki wearing, friction shifting DismalScientist, but it’ll be cool.
    #1042027
    Ironically, Di2 also solves a lot of the road/mountain shifting/gearing issues.
