A Tale Of Two Lights
Our Community › Forums › Bikes & Equipment › A Tale Of Two Lights
- This topic has 19 replies, 11 voices, and was last updated 11 years, 9 months ago by
cyclingfool.
August 23, 2013 at 10:36 pm #979223
ParticipantWhere are you riding? 250 isn’t much for riding at speed on unlit trails, but is probably fine for urban.
August 23, 2013 at 10:45 pm #979224TwoWheelsDC
This. I have a 300L and it’s what I would consider bright enough to get by, but I eventually put a 600L (Cateye something or other…) on my commuter and that’s about perfect, but battery life is a major concern. This fall, I’m putting a front disc on my commuter, and I think while I’m at it I’m going to throw a dyno hub on there….no more charging, no more batteries, no more worrying about running out of juice.
August 23, 2013 at 10:53 pm #979225DismalScientist
Participant18650s seem to be available from reputable:rolleyes: Chinese sources for under $2 each on ebay. The pricing on LIR123As seems to be similar.
Ebay has high power flashlights for under $20. And cheap handlebar mounts for these flashlights for a buck.
These flashlight take 18650s, but also have inserts that will take 3 AAA cells (wired in series).P.S. I ride with a 250 lumen Chinese flashlight on the bars and another tied to my helmet with a piece of tube. I found it sufficient for the deepest, darkest parts of the WOD in winter.
August 23, 2013 at 11:07 pm #979226hozn
ParticipantI run my lumina 350 in mid-level mode (250?), which is fine on the W&OD. I used to use a dinotte 200 which I also thought was fine. … But I would get the light that you definitely won’t need to change batteries on halfway home. In the pitch black, raining, etc.
August 24, 2013 at 11:29 am #979237americancyclo
ParticipantI’ve been happy with a 250 lumen rechargable light for the W&OD for the past few years. I love being able to charge it at work by plugging it in to the computer, and I can usually get 2.5 of 3 hrs out of it. The idea of having to worry about replacing batteries is a non starter for me.
August 24, 2013 at 3:24 pm #979240krazygl00
ParticipantGrrrrr…literally a couple of days ago there were both lights at several online sellers for great prices. Now the supply of the Power Drive seems to have completely dried up. I had no idea there was currently a fire sale on them but I seem to have missed out. And it’s too bad because due to the comments here I had started to lean toward that one.
In any case, I snagged one of the mini drive loaded kits (extra battery, several mounts, storage case) for a great price. I’ll give it a shot and see how it does. I’m sure I’ll be able to put it to good use no matter what.
August 24, 2013 at 4:58 pm #979241hozn
ParticipantIf you end up needing something with more juice, I strongly recommend the NiteRider Lumina line. There were issues with the old mounts, but no longer. And NR has great customer serice. In general lights have gotten so much cheaper; it is awesome.
I have been tempted by the Lezyne lights myself, though. I find myself slowly accumulating more and more Lezyne products; they make good stuff.
August 24, 2013 at 5:53 pm #979242americancyclo
ParticipantI’ve got the MiNewt USB which appears to be the precursor to the lumina line, 3 years on and no complaints other than the mount. Even that hasn’t been much of an issue for me lately
August 24, 2013 at 6:40 pm #979244dbb
The new mounts have a screw tightener. I wrote NiteRider and told them I really liked their lights but the mounts sucked and they sent me a new mount.
August 24, 2013 at 11:02 pm #979248DaveK
ParticipantI have a several-year-old Magicshine that’s been flawless, but I’m thinking of getting something like the Knog Blinder Road so I don’t have to bother with battery packs. It’s not quite as bright, but for the short distance I’m on NPS trails during my commute I think it’ll be fine.
http://www.knog.com.au/cms-new/no-ordinary-light.phps
August 28, 2013 at 9:09 pm #979697krazygl00
ParticipantRelated to this thread, perhaps someone more knowledgeable about batteries can answer: how can one evaluate cheaper, non OEM batteries to make sure they’re safe to use in a light? Now that I have a mini drive on the way, I want to stock up on some cheap spare LIR123As, but I’ve heard the cheap ones can be “out-of-spec”, which very well may be FUD tactics to sell the more expensive OEM batteries. I have a multimeter; is it simply a matter of measuring voltage and current and making sure they’re within a reasonable range of OEM? Or is there some other test?
August 30, 2013 at 2:40 pm #979867mstone
ParticipantFor anyone else looking, here’s a nice resource for comparing lights: http://road.cc/content/news/69237-big-roadcc-lights-test-2012 IF they have the light you’re looking at. You can compare the lezyne models and the knogs to get some idea of how lights can differ.
August 30, 2013 at 2:44 pm #979871Tim Kelley
ParticipantI just picked up a Light & Motion TAZ 1200, which in the few times that I’ve used it seems to be quite for nice for a really bright light in a small package with no external battery packs needed.
September 6, 2013 at 4:29 pm #980544CaseyKane50
I contacted NiteRider and just got the new mount for my MiNewt. A much improved mount! The new mount is on the right.
[ATTACH=CONFIG]3644[/ATTACH]
September 6, 2013 at 4:51 pm #980548mstone
wait, what held it on before? fairy dust and good wishes?
