$0 single speed "conversion"?
Our Community Forums Bikes & Equipment $0 single speed "conversion"?
  • #912434
    Is there anything wrong with just taking off the shifters (Shimano RapidFire style), unhooking the shifting cables, and adjusting the rear derailleur H limit screw in order to hit the cog you want / have the chain line (relatively) straight?
    I don’t have a single speed chain or sprocket laying around and I really just want to try a few SS rides. So I mucked around last night using the rear derailleur as a tensioner, and front derailleur/big ring as a chainkeeper. The chainring I chose is the middle of the existing triple (42T) and the rear cog is #3 in an 8 speed 12-25 cassette (15T).
    I can’t imagine it’s any more likely for the chain to come off than if it were all connected to shifters? Obviously with the jockey wheels and imperfect chainline the system will be less efficient than a true SS and the wear will be more concentrated but these are all older parts anyway. The only new parts were 2x Avid FR-5 levers I did happen to have laying around which I connected to the existing brakes/brake cables.
Viewing 3 replies - 61 through 63 (of 63 total)
  • #961217
    Hey, vvill do you want a ritchey carbon cx fork (canti brake posts) for your project? Alu steered but should be lighter than steel :)
    #961120
    Thanks for the fork hozn!
    #963426
    So I did a bit more setting up to get this thing running. I unbolted my first chainring tonight, no injuries, yay!
    [img]http://bikearlingtonforum.com/attachment.php?attachmentid=2464&d=1361935812[/img]
    Soooo tempted to go out for a trial run right now but probably gonna wait til the weekend or so.
    No doubt a good thing considering I haven’t connected brakes properly yet:
    [img]http://bikearlingtonforum.com/attachment.php?attachmentid=2465&d=1361935813[/img]
    The bar extension thing says “max load 0.3kg” :)
