$0 single speed "conversion"?
Our Community Forums Bikes & Equipment $0 single speed "conversion"?
  • #912434
    Is there anything wrong with just taking off the shifters (Shimano RapidFire style), unhooking the shifting cables, and adjusting the rear derailleur H limit screw in order to hit the cog you want / have the chain line (relatively) straight?
    I don’t have a single speed chain or sprocket laying around and I really just want to try a few SS rides. So I mucked around last night using the rear derailleur as a tensioner, and front derailleur/big ring as a chainkeeper. The chainring I chose is the middle of the existing triple (42T) and the rear cog is #3 in an 8 speed 12-25 cassette (15T).
    I can’t imagine it’s any more likely for the chain to come off than if it were all connected to shifters? Obviously with the jockey wheels and imperfect chainline the system will be less efficient than a true SS and the wear will be more concentrated but these are all older parts anyway. The only new parts were 2x Avid FR-5 levers I did happen to have laying around which I connected to the existing brakes/brake cables.
Viewing 15 replies - 46 through 60 (of 63 total)
  • #960562
    baiskeli
    @dcv 38217 wrote:
    Didn’t know where else to post this, this is pretty cool.
    They are not wearing helmets.
    #960538
    @hozn 41045 wrote:
    I recommend the Surly setup — good quality stuff; the cogs work with 8-speed chains and have wide bases. Some of the cheap conversion kits require SS chains (heavy!) and have narrow bases that will chew your freehub body up (well, especially if alloy). I am 95% sure that I have that set of Surly hub spacers zip tied together in my parts bin that you can have (from my first ss-converted mtb). And I may have a lightly used 16t or 17t cog. Send me a PM or email if interested.
    Thanks for the reply! I ordered my own set of stuff, can’t wait to try it out. (I need to get new brake pads though, the front ones are worn through after this week’s commutes.)
    #960878
    Hmmmmmm well. Mostly a success. The tall Surly cog though doesn’t seem compatible with the KMC X8.93 chain. I ended up just shortening my old stretched Shimano chain which fits in the tall cog teeth fine.
    But now I have a new shortened KMC chain that I don’t have a use for, and an old chain on a new cog. :(
    #960915
    That is odd. I have used a few of those chains with surly cogs (they are nice and cheap!). What size cog is it? (And is it otherwise special?)
    #960921
    Nope just the standard 3/32 Surly cog, size 15T.
    The chain had trouble engaging each tooth, even with just gently turning the pedals (by hand) on a bike stand.
    Yeah I thought it was odd too but when I did some Googling I found a few forum posts about it. Some people apparently took a file/grinder to the corners of the teeth to make it work.
    #960963
    Interesting — and good to know for the future. I have definitely used 2 different KMC X8.93 chains with my Surly chainring & cog setup on my horizontal-drop SS MTB, but I have probably just been lucky. Maybe also the larger cogs are less likely to have this issue (18t/20t) due to angle of the cog teeth (??) … that is just spitballing, haven’t applied any science there :)
    #960967
    OneEighth
    Phil Wood cogs.
    I have ridden with several sizes of Surly cogs and—for me—the savings per cog aren’t worth the cost in ride quality or chain wear.
    #962202
    Thanks, but aren’t Phil Wood cogs just for track hubs? I just have a standard Shimano/SRAM splined 130mm wide hub right now.
    It could well be that it’s a problem with the smaller cogs. Makes sense anyway.
    For now I am just going to make sure I carry an 8 speed quick link and chain tool with me whenever I ride this bike. I cleaned the chain as well as I’ve ever cleaned the chain (which is to say, not much – but it’s no longer black) and it looks in decent shape still, even if it is a bit stretched.
    #961609
    My conversion is no longer $0. I suppose this was inevitable, but it’s cheaper than a new frame.
    #961602
    Jason B
    Congrats on the wheel, you may not be invited to anymore track stand/tattoo competitions the bike rats have under the 66 overpass, but you will have some serious tension.
    But seriously, check out this invaluable eno video dcv sent me on this thread (sorry haven’t figured out the how to embed yet. btw, is that a matching white cog???ooh la la!
    http://bikearlingtonforum.com/showthread.php?3629-Short-19mm-wrench&highlight=Wrench
    #961600
    dcv
    I saw that ENO wheel on CL on Friday, and almost emailed the seller to buy it. Are you going fixed?
    BTW you just opened pandora’s box – you will start noticing all the framesets on CL that you can convert to fixed, especially the CF ones.
    #961582
    Heh, thanks. I will need to figure out how to take the wheel out for flat changes etc. The cog it came with is just a Surly 16T 1/8″. I guess it’s an older ENO hub (no splines).
    I’m planning to start out running it SS for my morning commutes and then depending on how I feel, trying FG for my return commute or some lunch laps at Hains Pt. My closest calls/accidents that are my own fault seem to happen more in the AM and I know I’m often still waking up when on the bike then too. I’m in no rush though, I just got this now because it seemed like a good deal for the future.
    I may have opened pandora’s box but I see it as costing a lot less than a new bike! I was seriously considering a Wabi but I’ve been enjoying my cheap hybrid’s ride (on a decent wheelset) so much I didn’t want to buy something online and then feel like it wasn’t as good as what I already have. And now I can try fixie without as big a commitment, and if it doesn’t take at least I have a nice SS without a tensioner.
    #961578
    …you may not be invited to anymore track stand/tattoo competitions the bike rats have under the 66 overpass…
    Please tell us more.
    #961400
    dcv
    Hey VVill, this would go nicely with that wheel: http://washingtondc.craigslist.org/doc/bik/3585172968.html
    #961387
    Ha, I actually already saw that last night!
    I *am* thinking if I get a frame it’ll be a CX one, or just basically anything roadie-like that can take larger tires. That frameset is very close to my road bike actually – hydroformed Al, carbon seat stays, carbon fork.
    But the hybrid I’m riding now can take 32s already so I am thinking of doing “just a couple” of upgrades on it, and calling it a day. My CX bike covers the hybrid’s previous duties well enough (kid towing, other utility stuff) so I think I’m holding off on anything new for a while. Trying to, anyway! I’m curious how light I could get this thing – since the fork is steel I could lighten that easily.
    I’ve taken off the lockring on the ENO wheel and cleaned it a bit but that’s it so far. Trying to get some use out of the Surly cog/spacer kit I also only recently bought, although they will most likely end up with a new life on my beater MTB which I’ll convert to SS too one day.
